From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
Need HVAC Help - Heat & AC at the same time
Once again I need the wisdom of the forum members.
I'm stumped. Today I jump in the vette and the two driver side vents are blowing hot air and the passenger side is blowing ice cold AC??
Since the passenger side vents are blowing ice cold with the ac on and the auto temp set for 62°F I'm assuming it's and electrical issue in the HAVC control and not an AC compressor problem.
Any ideas on what the problem could be?
Thanks!
I've read quite a few posts where people have this exact issue recently. Seems to almost always be that the car is low on freon. Try getting a recharge...
Yep, looks like an actuator issue. Here's the first thing to try now. Clear the codes. This will cause the actuators to recalibrate. Then pull the codes again. If they come back, then you need an actuator. Here is what that actuator looks like broken:
