Engines dies, restarts, has intermittent issues, help
Pull codes. Lots of history.
c1214 HC ( been there a while, traction screwed up.)
u1096 H on sdm
b0521h, u1255h, u1160h on ipc
u1096h on next one
b0361hc on hvac
b2282h, b2286h,b2284h,u1096h on ldcm
rdcm has 10 codes, b2203, 5, 7, 9, 2283, 87, 85, 65, 73, u1096. door window, locks are screwed, need to fix
u1000h,u1096h on rfa
I am pretty savy on things, understand how electrical works mostly, mech engineer.
What is my best bet. I am scared to drive the car very far. Is redoing all the grounds my best bet at the motor and front frame. what else can be going on.
thanks in advance.
PS, how do i clear all the codes? just pull power? radio then needs reset.
u1096 H on sdm
u1096h on next one
b0361hc on hvac
thanks in advance.
You clear codes by holding down the reset button within each module. Holding down the reset button will clear all codes within that module, not just the one that is displayed (I'm assuming you're reading codes from the DIC and not using an aftermarket scanner). Definitely reset them and see which ones come back.
Have you checked the wiring at your alternator? Is the grounding screw in tight?
