I-sharft torque
Old Sep 17, 2011 | 03:03 AM
IAIA's Avatar
IAIA
Default I-sharft torque
Anyone know the torque spec on a C5 Z06 intermediate (steering) shaft? It's not shown on that "torque + specs" jpg list that's always floating around.
Thanks!
Old Sep 17, 2011 | 04:03 AM
shadowman1's Avatar
shadowman1
Intermediate shaft to column pinch bolt 35ft lb
Intermediate shaft to steering gear pinch bolt 25ft lb
Old Sep 17, 2011 | 04:06 AM
IAIA's Avatar
IAIA
Wow. Great!
Can you let me know the source?
Thanks.
Old Sep 17, 2011 | 04:07 AM
shadowman1's Avatar
shadowman1
GM service manual. Got it sitting right here.
Old Sep 17, 2011 | 04:11 AM
IAIA's Avatar
IAIA
Cool. Thanks again.
Not a commonly replaced part, from what I hear.
Old Sep 17, 2011 | 04:16 AM
shadowman1's Avatar
shadowman1
Chevy has a recall on a lot of steering shafts and has redesigned it many times for a noise complaint. Kind of a clunking noise when you hit a bump while turning. I'm not sure about the shaft on the vettes but I have changed many of them on their sedans and even more on their trucks. There is a service bulletin on it. I don't have access to the bulletins right now.
Dave
Old Sep 17, 2011 | 04:42 AM
IAIA's Avatar
IAIA
Yeah, I have a clunking noise on bumps but not while turning. But the dealer replaced the shaft, and it did nothing. The clunk is closer to the firewall, maybe even on the inside. Truth is, sounds more like a loose speedo or cable rattling in there.
So they agreed to switch it back out. I don't think the recall covers 02 Z06's or they probably would've known. Where are you located, by the way, and do you do repairs for the public?
Old Sep 17, 2011 | 06:38 PM
IAIA's Avatar
IAIA
A new question: when replacing the I-shaft, does the steering wheel have to be re-aligned--straight up and down--or is it not a function of the replacement?
Old Sep 17, 2011 | 08:58 PM
m6 c5's Avatar
m6 c5
As far as I know the only way to install it incorrectly is a full turn of the wheel where you will have other problems.
Old Sep 18, 2011 | 03:37 AM
shadowman1's Avatar
shadowman1
Before you undo the bolts and pull the shaft loop the seat belt thru the steering wheel to prevent it from turning. It should only line up one way but you don't want the wheel to get out of sync you could break your clockspring.
Dave
Old Sep 18, 2011 | 12:51 PM
IAIA's Avatar
IAIA
Thanks for the info.
To I-sharft torque
