"low oil level"
Old Sep 17, 2011 | 10:08 PM
aschiftner's Avatar
aschiftner
Default "low oil level"
Changed the oil back in April. Just yesteday I got the Low Oil Level display on the DIC. Don't see any leaks under the car or around the engine. Sure enough the oil was at the bottom line on the dipstick.
I will probably pull some of the plugs tomorrow. Did a plug change in April also and all was normal in there.
Is there something common as to why I lost the oil?
Thanks. V/r Al
Old Sep 17, 2011 | 10:14 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
Mine went on today also, level is fine, sensor on passanger side of oil pan defective i guess.
Old Sep 17, 2011 | 10:45 PM
aschiftner's Avatar
aschiftner
8VETTE7, thanks for the reply. I tried to explain the vapor catch can to my aircraft mechanic buddy with no success.
No I do not drive the vehicle hard.
It is a 2002 A4 with 70,000 miles.
Old Sep 18, 2011 | 06:09 AM
65GGvert's Avatar
65GGvert
Did you look at the dipstick anytime before the low oil warning came on? It's possible it was not filled properly and just tripped the monitor now. If it was full and then at the bottom of the stick later, a catch can might let you know what's happening.
Old Sep 18, 2011 | 07:10 AM
04blackice's Avatar
04blackice
My04 z uses oil also.mabye half qt between changes
Old Sep 18, 2011 | 10:13 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Mine does that too. I think it tends to be the normal although I'm not positive.
Old Sep 18, 2011 | 03:55 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
My 04 uses oil as well , have to add at leat 2 to 3 times between oil changes. I drive it hard all the time, its running great so I just add when needed and keep on hammering on it. It started this about 10K miles ago, its cammed and has about 90K on the clock.
Old Sep 18, 2011 | 04:01 PM
dossdrop's Avatar
dossdrop
It's more than likely the oil level sensor on the passenger side of the oil pan. I got a low oil level light on my 01' but when I checked the oil level was fine.. Bought a new sensor from my local oreilly and it fixed it... They are known to go bad from time to time.... I would wait until your next oil change to swap sensors... Quite a bit of oil comes out when you swap sensors....
Old Sep 18, 2011 | 04:33 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
.... My 04Z does also...
I tend to run it thru high RPM's from light to light though too. Just cause I like the sound of the Heads/Cam..
Toque
Old Sep 18, 2011 | 05:00 PM
Chicago1's Avatar
Chicago1
Toque
+3 I like the way the 1 7/8" SW LT's and B&B sound at higher rpm just to addicting. I have to add about a quart in between mine is a 01
Old Sep 18, 2011 | 05:23 PM
sfc rick's Avatar
sfc rick
I'm running hard and I'm using some also. I don't consider it a big deal!
Old Oct 30, 2011 | 01:30 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Mine just did this on my weekend trip to my camper. Scared the crap out of me. I'm thinking ok what's this and what's next. I was about a quart low so I filled it up and the message still kept coming on.
Almost ready for an oil change anyway so I guess I'll be changing the sensor.
So I repeat myself, what's next?
Old Oct 30, 2011 | 01:35 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I had this happen recently and couldn't get the message to clear so I disconnected the battery and reconnected...message never came back..
Old Oct 30, 2011 | 01:57 PM
RetiredSFC 97
Thanks, I'll try that!
Old Oct 30, 2011 | 02:49 PM
pewter99's Avatar
pewter99
FWIW I have been reading about members switching oil and solving the consumption issue. The new Pennzoil Platinum has been getting good reviews on here...been considering it myself since I have no warranty to worry about
Old Oct 30, 2011 | 03:37 PM
Toque's Avatar
Toque
I use a little oil. Just figured it was normal. There is a different oil which stops/reduces this ?
Toque
Old Oct 30, 2011 | 04:48 PM
ZeeOSix's Avatar
ZeeOSix
Toque
Mixed reviews ...
http://forums.corvetteforum.com/c5-t...ultra-now.html
Old Oct 31, 2011 | 02:42 PM
jimcork1's Avatar
jimcork1
FWIW I since new I have been using M1 10W30 with no issues. I also use no oil between changes on the oil minder. I have 89,000 miles and it stilll doesn't use any oil (not have to add and not a qt down). But granted it is a 99 w/o the ring issue.
To "low oil level"
