Tire pressure monitors
Old Sep 17, 2011 | 11:50 PM
RLDaily's Avatar
RLDaily
Default Tire pressure monitors
Can putting air in your tires screw up your monitors?
My tires were all showing 26-27 lbs and my RF warning came on a few times @ 25lbs, so I aired them all to 30 lbs...Now my TPS shows nothing for any tire...I'm not getting any kind of warnings but when I check there are no readings.
Old Sep 18, 2011 | 01:08 AM
johnpowe's Avatar
johnpowe
The system will not show correct readings until speed reaches at least 15 mph. So If you just air the tires up and didn't drive it, the system just isn't receiving the signal and you need to drive it up to speed. If you have done that then I would do the relearn procedure for each tire sensor. I think the procedure is in the owners manual or you can do a search in the forum and there are threads that detail the correct procedure. Your will need a fairly strong magnet to do the relearn procedure. If the relearn trick doesn't work then more troubleshooting will be required. Though it would surprise me very much if the all sensors are bad. Having all sensors go bad at the same time would be so unusual that it borders on the impossible. I would suspect a communication problem if the relearn procedure doesn't work.
good luck
Old Sep 18, 2011 | 06:01 AM
65GGvert's Avatar
65GGvert
If putting air in tires screwed up the sensors, there wouldn't be a working set out there. Drive it and report back what happens.
Old Sep 18, 2011 | 10:15 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Each sensor has a centrifugal switch in them which means the wheel needs to spin fast enough to activate the transmitter in each. Therefore driving it as suggested should being them to life.
Old Sep 18, 2011 | 05:15 PM
Jewjenk's Avatar
Jewjenk
Now that takes the cake....
Old Sep 19, 2011 | 01:30 AM
Junkyard_Dog's Avatar
Junkyard_Dog
Take the car for a 20 min drive. If the system detects a sensor not sending signals it turns on the "Service TPMS" message and displays XXX for the tire pressure.
Old Sep 19, 2011 | 11:29 PM
_zebra's Avatar
_zebra
winning thread for the day?
i vote yes
Old Sep 19, 2011 | 11:48 PM
RLDaily's Avatar
RLDaily
They work!
I just moved over from a C4 so I'm a bit DUH right now
Old Sep 19, 2011 | 11:49 PM
jrose7004's Avatar
jrose7004
Drive it around the block and they'll read just fine.
To Tire pressure monitors
