99 gauge wire schematic
Old Sep 19, 2011 | 05:10 PM
al89's Avatar
al89
Default 99 gauge wire schematic
i am putting a 99 gauge pod in a another car and need the wire diagram .does any one know i can find it
thks
Old Sep 19, 2011 | 05:20 PM
lucky131969's Avatar
lucky131969
thks
Are you referring aftermarket gauges for the pillar?
Old Sep 19, 2011 | 06:55 PM
al89's Avatar
al89
no i am putting a 99 gauge cluster (speedo) in a custom street rod , i know gm kept useing the same wire colors, i just dont remember them all
thks
Old Sep 19, 2011 | 06:57 PM
lucky131969
thks
Wire colors? How do you plan on reconciling the class 2 communication?
Old Sep 19, 2011 | 07:19 PM
al89's Avatar
al89
its running a ls2 super charged mtr and 6 speed trans . i have done it before with 95 camaro dash pod on a ls 1 40 gmc pick up
thks
wayne
Old Sep 19, 2011 | 07:30 PM
lucky131969
thks
wayne
Well Wayne, things changed a little bit after 1995. The following gauges(for a C5) operate based on communication with the PCM(over the class 2 serial data line):
1) Coolant temp
2) Oil pressure
3) Fuel
4) Speedometer
You'll need a PCM to make this happen, and the appropriate sensor inputs to the PCM i.e. coolant temp, oil pressure(has to be correct type), modified fuel sender circuit, VSS.
Old Sep 19, 2011 | 07:37 PM
al89's Avatar
al89
i will be running a pcm
thks
wayne
Old Sep 19, 2011 | 07:43 PM
lucky131969
thks
wayne
Ok, just trying to help here, so I'll part with this. Aftermarket PCM's most likely will not have provisions for class 2 communication, unless they are a replacement for a C5.....so you'll need a C5 PCM. With regard to F-bodies, I know that as late as 1998, the oil pressure, and coolant temperature were direct from the sensor to the instrument.
Good luck
To 99 gauge wire schematic
