TPMS Issue
Old Sep 20, 2011 | 05:23 PM
Normseven's Avatar
Normseven
Default TPMS Issue
My LF sensor is bad, will the other three still program, also what is the best magnet to get. 2001 M6 Coupe.
Old Sep 20, 2011 | 06:42 PM
'02magredZ51's Avatar
'02magredZ51
You got it. The other three will function normally.
Any fairly strong magnet will do. I used one off the fridge that always seemed to stick pretty well.
Old Sep 20, 2011 | 06:45 PM
baxsom's Avatar
baxsom
speaker magnet, magnetic parts tray. i've used both with good results
Old Sep 20, 2011 | 11:53 PM
jrose7004's Avatar
jrose7004
About any mildly strong magnet will do. I actually have one with a GM part number.
Old Sep 21, 2011 | 08:29 AM
65GGvert's Avatar
65GGvert
But, if the left front is bad, won't the car think (if you start with the rf) that the rf is the lf, rr is rf, and lr is rr? Or if you linger too long at the lf, not program at all and exit the program? It has to see the lf first and if you go to the rf, it assumes that is the lf?
Old Sep 21, 2011 | 09:00 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
It must be done in the exact order as specified in the owner's manual:
LF RF RR LR
The OP should be thinking about replacing ALL his TPMS sensors.
They are probably the originals, and nearly 11 years old.
Old Sep 21, 2011 | 06:06 PM
'02magredZ51
LF RF RR LR
And when he does remember to ask for the nuts and seals as well. From GM the sensor comes as just the sensor (valve stem and black piece as an assembly).
Old Sep 22, 2011 | 08:30 AM
Quicksilver Vert 01
'01-'04 sensors have the stem seal already on them. The nuts can usually be cleaned up and reused with the new sensors.
To TPMS Issue
