Ac
Old Sep 21, 2011 | 06:46 PM
ultraclassic01's Avatar
ultraclassic01
4th Gear
Default Ac
Any idea's on why the blower is not blowing on AC unit. Even when the fan is set to high very little air comes out. Also on high the fan sound gets louder. I heard that mice like to get in this blower unit. Anyway to check for this and where is the blower unit. Also heard something about re setting something for the actuators???????? Any help!!!!!
Thanks 99 C5,65,000. I think this car is ready for the donation pile with all the problems I am having this summer. Oil sending unit, and TC,ABS lights etc. etc.
Thanks again!
Old Sep 21, 2011 | 07:29 PM
cdkcorvette7's Avatar
cdkcorvette7
Post your DTC codes. You should have some HVAC codes set.
Originally Posted by Bill Curlee
POST DTCS!!!
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Sep 21, 2011 | 10:44 PM
dmarkshark's Avatar
dmarkshark
Blower is under the passenger side dash.
Old Oct 11, 2011 | 07:39 PM
bighank's Avatar
bighank
Default If its air out of all outlets with no change in mode you have a bad vacuum line
Battery acid eats the vacuum lines under the battery and causes air to come out of all outlets. If this is your problem go take out battery and battery bracket, wash with baking soda. splice in windshield hose to GOOD parts of hard plastic line. If it really is the blower remove it and test with 12 Volts. My electronic speed regulator (also under passenger dash but in the top corner) was blown and would not run the motor. It could also be a bad ground on the motor. Diagnose and fix the right problem.
Old Oct 11, 2011 | 08:28 PM
lucky131969's Avatar
lucky131969
Feel free to donate that piece of junk to me. I'll come pick it up, and take the burden off your hands.
Old Oct 12, 2011 | 08:20 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Good one lucky!
Old Oct 12, 2011 | 09:32 AM
rebelheart's Avatar
rebelheart
Sure sounds like a vacuum leak......
Old Oct 12, 2011 | 09:39 AM
cdkcorvette7
It's been three weeks since the op posted in this thread...
Old Oct 12, 2011 | 02:14 PM
BigGun's Avatar
BigGun
Well...what did you expect. He gave the car to Lucky!
Old Oct 12, 2011 | 02:21 PM
cdkcorvette7
To Ac
