Charging System Fault
Old Sep 21, 2011 | 08:17 PM
skeeters65's Avatar
skeeters65
Default Charging System Fault
I have noticed my car will say this every now and then when I start it up. Then it goes away..
What does it mean??
Old Sep 21, 2011 | 08:25 PM
dougbfresh's Avatar
dougbfresh
Weak battery most likely, do you leave it for long periods off a trickle charger?
Old Sep 21, 2011 | 08:35 PM
skeeters65's Avatar
skeeters65
The last couple times I have seen it say that the car had been driven the same day or just the day before..
Old Sep 21, 2011 | 10:47 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If it comes on and goes off shortly after the engine starts,, its nothing to worry about.
If the car is NEW to you,,, I recommend removing the battery terminals, cleaning them and reconnecting them using the correct torque:
97-2003 = 11 ft/lbs
Also check the NUT on the back of the alternator on the BATT Terminal. It should be clean and tight.
You should also MAKE SURE that the "STARTER SOLENOID" wire connections on the main solenoid terminal are clean and tight.
The alternator to battery connection goes thru the main connection on the solenoid.
To Charging System Fault
