Pull key wait 10 seconds....car dies when moving
Old Sep 21, 2011 | 09:48 PM
Rickof08's Avatar
Rickof08
Default Pull key wait 10 seconds....car dies when moving
The other day I disconnected my battery to clean some electrical connections.(I have a long dirt driveway) After I reconnected the battery I got in the car and started it up. It immediately displayed Pull key, wait 10 seconds. I followed the instructions several times but it still comes back up. So I decided to ignore it after a while and reversed my car out of the driveway. This ended in the car stalling right as the mph needle got off 0mph. Needless to say my car has been stuck in the driveway for a few days now. I tried google searches and trouble shooting but I keep coming up with "column lock" threads but my column doesnt lock whether its on or off. Any ideas?
Old Sep 21, 2011 | 10:13 PM
Blue Angel's Avatar
Blue Angel
Try disconnecting the battery and reconnecting it again. Apparently the column lock circuitry is sensitive to voltage. There's a proper torque to fasten the battery terminals to. Do a search, lots of info, one of (if not THE) most popular Corvette failure modes.
Old Sep 21, 2011 | 10:50 PM
SUPERCRUZ's Avatar
SUPERCRUZ
Pull codes from the DIC and report back.
Old Sep 21, 2011 | 10:51 PM
xomega's Avatar
xomega
you need the colum bypass kit.... try searching. i had the same issue last year.
Old Sep 22, 2011 | 12:58 AM
Rickof08's Avatar
Rickof08
So I found one thats still current B2723 HC Passkey detection Circuit. That explains why I have to ghetto start my car every once in a while but doesnt explain the car dieing and the pull key wait 10 seconds message. Ill look into the column bypass also.
Old Sep 22, 2011 | 01:50 AM
Rickof08's Avatar
Rickof08
Well I reckon its time for a new ignition switch. I tried cleaning the connections in it a while ago when the Passkey issue started.....I lost a spring that moves the little studs haha Ever since then the Security light has stayed on. Ive just never had any issues until now.
Old Sep 22, 2011 | 06:48 PM
Rickof08's Avatar
Rickof08
I called my local chevy dealer and they said the column lock recall was done on my car in 04. That explains the column not locking. Could it still be that I need a CLB?
Old Sep 22, 2011 | 07:16 PM
lucky131969's Avatar
lucky131969
Well, there is your answer. You might as well replace the assembly.
Old Sep 22, 2011 | 08:54 PM
SueTaing's Avatar
SueTaing
I had the same exact problem.
I didn't want to install a CLB as I already have the K harness and knew there were two security features on the PCM.
1. Lock steering (that is not your issue)
2. 2 mph cut off
I had HP Tuners so I set the cut off to 200mph.
Light comes up once and goes away after I reset but I can drive my car without having to spend on parts/service.
Old Sep 23, 2011 | 12:41 AM
Rickof08's Avatar
Rickof08
I decided to pull the dash piece off under the steering wheel and what do you know, a black box plugged into the harness....I guess I already have a CLB installed. Well its time to start throwin parts at it.
Old Sep 23, 2011 | 12:44 PM
Rickof08's Avatar
Rickof08
I need a new ignition switch anyways, nothin to lose by replacing it.
Old Sep 23, 2011 | 04:27 PM
Matti's Avatar
Matti
Any chance your alternator is going/has gone bad?
Old Sep 23, 2011 | 06:03 PM
alankb's Avatar
alankb
Default contacts
You probably lost the spring behind the passkey contact.
Old Sep 23, 2011 | 09:47 PM
n8dogg's Avatar
n8dogg
A few things you can try which have proved to be + on some vettes I've worked on:
1.) Perform BCM reset... remove neg cable from bat, remove connectors at BCM. Leave disconnected for 1 hour.
2.) Remove fuses 29 and 25 under the dash while you are performing the BCM reset.
3.) Replace the column lock relay under the dash, above the BCM.
4.) Install CLB... you can still get the pull key wait 10 sec if the CL relay is bad.
5.) Get a tune done and ask for the column lock feature to be removed.
Old Sep 24, 2011 | 10:26 AM
AntonioZ06's Avatar
AntonioZ06
for what it's worth....
My car had a similar issue. I had column lock but tuner turned up the fuel cut off. I diagnosed it to a bad battery, replaced it. Column lock was fine but still had Wait 10 seconds....
My car had the recall done so before I bought a CLB I checked to see if it had a K Harness. It did. I removed it from under the steering wheel, and no more issues to this date a year later. These K Harnesses seem to periodically fail or internally short causing this issue.
At least that's what it was for me.
To Pull key wait 10 seconds....car dies when moving
