Compression test - OK to do without exhaust or throttle body?
Old Sep 22, 2011 | 12:21 AM
YELLO C5's Avatar
YELLO C5
Default Compression test - OK to do without exhaust or throttle body?
Hydrolocked the 2000 but got it running again. Throwing a P1515 so I ordered up a throttle body. While I'm waiting for it I'd like to do a compression test and install headers. Is it OK to do a compression test without the throttle body and exhaust? I assume I'm just looking for readings within 10% on all cylinders.
Old Sep 22, 2011 | 12:33 AM
lucky131969's Avatar
lucky131969
Yes, you are only reading cylinder pressure.
Old Sep 22, 2011 | 02:22 PM
PDQC5's Avatar
PDQC5
You could always try doing a leakdown test instead of compression, no need to run the motor
I meant no need to spin the engine over with the starter. LOL
Old Sep 22, 2011 | 04:50 PM
lucky131969
How do you figure? You still need need to have each cylinder at TDC.
Old Sep 22, 2011 | 05:20 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
It's perfectly fine doing it that way.
Back in the days of carburetors, they even recommended holding the carb throttle plates open, when doing a compression test, to allow sufficient air to enter the cylinders.
Old Sep 22, 2011 | 06:31 PM
YELLO C5's Avatar
YELLO C5
Thanks everyone!
To Compression test - OK to do without exhaust or throttle body?
