ABS light question?
Old Sep 22, 2011 | 09:35 PM
Donrico1's Avatar
Donrico1
Default ABS light question?
My 97 is displaying abs light about half the time. Usually comes on after a good bump. I'm aware of the EBCM problems but all my codes relate to the RR wheel sensor. Pulling the following codes
C1224 H
C1228 H
C1235 H
Theses are the only codes
Old Sep 22, 2011 | 09:38 PM
dmarkshark's Avatar
dmarkshark
You might try looking at the rear wheel sensor, cleaning it, and making sure it has a good connection. My 99 did this on the front wheel, I did this, and have not seen any display probs for quite a while now.
Old Sep 23, 2011 | 09:03 AM
dougbfresh's Avatar
dougbfresh
C1224 H
C1228 H
C1235 H
Did you look these up? Maybe there's a CLUE???
Old Sep 23, 2011 | 10:22 AM
cdkcorvette7's Avatar
cdkcorvette7
Check the electrical connector at your wheel speed sensor at your right rear wheel...
C1224 RR Wheel Speed Sensor Input Signal is 0
C1228 RR Excessive Wheel Speed Variation
C1235 RR Wheel Speed Circuit Open or Shorted
Old Sep 23, 2011 | 10:50 AM
dougbfresh's Avatar
dougbfresh
Originally Posted by cdkcorvette7
Check the electrical connectors at your wheel speed sensors at both rear wheels...
Right REAR in particular! Nice CLUES huh?
Old Sep 23, 2011 | 07:15 PM
Bill Dearborn's Avatar
Bill Dearborn
It could be the wheel speed sensor or it could be the EBCM. The first EBCM had a design issue that caused errors just like the one you are seeing. I flat spotted a number of tires when autocrossing with my 97 due to the ABS failing when going over bumps. It took close to two years to get the updated EBCM to the field and not many people had them installed since they didn't drive the cars enough to find the problem. If it is the EBCM one way to solve the problem is to mount a toggle switch on the center console that allows you to turn the EBCM power off and back on every time it fails. The EBCM will reset, do its self check and work fine until the next special bump.
Bill
Old Sep 23, 2011 | 09:36 PM
Donrico1's Avatar
Donrico1
I think I got it. No more lights, time will tell. Thanks for all the advice.
Old Sep 24, 2011 | 10:45 AM
87SAM's Avatar
87SAM
What did you do? When people use the search function for similar problems, the quote “I think I got it” will be of no help to them!
Old Sep 24, 2011 | 11:19 AM
cdkcorvette7
This.
Was your connector loose?
Old Sep 25, 2011 | 09:42 PM
Donrico1's Avatar
Donrico1
Ok here is what I did.
The first thing I did was make sure battery was fully charged and it was,then I went thru and cleaned up four of the main grounding points.
http://forums.corvetteforum.com/c5-t...tion-long.html here is the link. Then I pulled the connector on the RR wheel sensor cleaned it and snapped it back on. It's been three days and no abs or tcs lights.
Old Sep 25, 2011 | 10:06 PM
87SAM's Avatar
87SAM
Good to hear!
Old Jul 31, 2013 | 05:04 PM
Take5's Avatar
Take5
Cruising
What grounding points did you clean? also how did you clean the connector? Im having these same codes and i cant seem to get them to go away
To ABS light question?
