Shifter installation question
Old May 2, 2002 | 12:41 PM
Joecooool's Avatar
Joecooool
Jax Events Coordinator
CI 3-4-5-6-7-8-9 Veteran
St. Jude Donor '03-'08
Default Shifter installation question
How long did it take to replace the stock shifter? Does anyone have a site set up with the step by step?
Old May 2, 2002 | 12:45 PM
jefffxdwg's Avatar
jefffxdwg
Default Re: Shifter installation question (joecooool)
About 20 minutes, very straight forward.
Old May 2, 2002 | 01:26 PM
Nate@CorvetteGarage's Avatar
Nate@CorvetteGarage
Supporting Vendor
Cruise-In I Veteran
St. Jude Contributor '04
3 torx screws, 4 ten mm nuts hold the console in place. The hardest part of the install is getting the push T-pin removed from the stock shifter ****. Vice grips or two stright edge screw drivers will do the trick. The install is very basic. 1 hour tops for a novice.
Nate
Old May 2, 2002 | 01:28 PM
Patches's Avatar
Patches
Here's the site I put together a few weeks ago, Joe.
http://temp.corvetteforum.net/c5/pat...rInstall.shtml
:yesnod:
Ed
Old May 2, 2002 | 03:31 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
You can make it even easier. You only have to remove the skirt around the shifter - it pops right out. Then access the bolts that attach the shifter to the frame. Becareful not to loose the position pin when you lift the stock shifter out. Install the new shifter and replace the skirt. This take about 5 minutes.
rr
Old May 2, 2002 | 03:33 PM
Crushinator's Avatar
Crushinator
Default Re: Shifter installation question (Road Runner)
Very easy. Took my a total of 1 hour from start to finish and I tool my good old time. I used Patches instructions. They're exact!
Old May 2, 2002 | 04:21 PM
Joecooool's Avatar
Joecooool
Default Re: Shifter installation question (Patches)
:yesnod:
Thanks - I like your site. I already finished the install, wish I had seen that first. By the way, if you are not going to change the boot, you do not need to take it off. I left mine in place when I did the job. Here is my mess -
Old May 2, 2002 | 04:41 PM
Patches's Avatar
Patches
:cool: Good tip about the boot!
I take it you like the Hurst? :D
To Shifter installation question
