Hypertech Power Programmer Users . . .
Old May 2, 2002 | 12:59 PM
Humy's Avatar
Humy
Default Hypertech Power Programmer Users . . .
I can program my Vettey to the power tuning just fine and it runs awesome. However, when I program it back to stock - the car turns on for a second and then shuts off. And trouble codes start to come up. Then if I program the car back to the Hypertech power tunning, it runs fine again :confused: :smash: :cry . Anyone have this problem? :nopity
:cheers: :seeya :chevy thanks for any insight in advance :flag
Old May 2, 2002 | 01:08 PM
B. Stewart's Avatar
B. Stewart
Default Re: Hypertech Power Programmer Users . . . (Humy)
Never had that problem. I can put it back to stock without any problem. You may need to contact Hypertech.
Old May 2, 2002 | 02:23 PM
THRAP 42's Avatar
THRAP 42
Default Re: Hypertech Power Programmer Users . . . (B. Stewart)
Humy,
Same as B. Stewart here. I've gone back and forth 6-8 times and have not had any problems. Have you watched the programmer during the return to stock? If something goes wrong is will give you a code. First time I ever used mine it lost connectivity and gave me a code. I called hypertech and they told me what had happened. Made sure that I didn't move the unit or cable since and have had no problems.
later,
Old May 2, 2002 | 04:22 PM
LovintheC5's Avatar
LovintheC5
Default Re: Hypertech Power Programmer Users . . . (THRAP 42)
Make sure your battery is fully charged before starting. If not, it will interrupt, and could cause it not to start
Daren
Old May 2, 2002 | 07:52 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Hypertech Power Programmer Users . . . (LovintheC5)
Never a problem here... :seeya
Old May 2, 2002 | 08:24 PM
JT-C6's Avatar
JT-C6
Cruise-In IV Veteran
St. Jude Donor '03-'06-'08-'10-'11
Default Re: Hypertech Power Programmer Users . . . (pewter99)
I can help! I know the problem, I had the problem too. It is a theft deterrent issue. When you return to stock, the hypertech doesn't do a nice cleanup job on the firmware. What you need to do is return to stock, try and start. The car will run for a second or so and then shut off. Connect the hypertech again, let it start up, let it validate the VIN, then once it prompts you to program again, do nothing. Shut the car off, disconnect the programmer. Restart the car, it will fire right up.
I got this solution directly from Hypertech, it works perfectly. It is certainly not a desirable situation, but they say its a known issue.
Old May 2, 2002 | 09:05 PM
VetteDawg's Avatar
VetteDawg
Sounds like 'JT' has the answer. Let us know how you make out.
I like the part where it says 'Reduced Engine Power' about 50% through the tuning (it does on my 2000 anyway) - not exactly what we have in mind is it? :)
Old May 3, 2002 | 10:15 AM
Humy's Avatar
Humy
Default Re: Hypertech Power Programmer Users . . . (JT-C5)
:cheers: :seeya :chevy :cheers:
Old May 3, 2002 | 10:16 AM
Humy's Avatar
Humy
Default Re: Hypertech Power Programmer Users . . . (Aln)
:lol: :yesnod: :smash: :cool: :flag
Old May 4, 2002 | 05:48 PM
JT-C6's Avatar
JT-C6
I know, I get reduced engine power message and all sorts of clicking and flashing. It may not be the prettiest programming, but it works.
I know the warm start after validating VIN will fix the "no start" issue.
To Hypertech Power Programmer Users . . .
