So, if I read the shop manual correctly, the fans pull up, then back a bit and are pushed out the bottom of the car. Correct? After the top support is removed of course. And the wiring disconnected.
While trying to fit the VR power duct, I took the top radiator support off to see if that added clearance would help. Discovered at that time that the front of the radiator and AC condensor are filled with debris. No wonder the car wants to run hot. And maybe no wonder that a previous owner altered the fan turn on temps to both come on at 188 degrees. Easier than hosing out the radiator.
Oh, and the middle portion of the lower air deflector is also missing. I have a new set ready to go.
Let me know if I got it right.
BTW......where do folks mount an auxillary Auto Trans cooler?
Not sure what plastic you are referreing to. My factory fans were in "new" condition when I sold them earlier this year. Here is a link with pics of them. I now have some aftermarket fans that draw twice + the CFM the factory fans did. Because of the Maggie I now have installed I had some heating issues in the southern Az. summer heat..... Once the air cleaner system is off they came right out the top with no interference from anything. If you get the car high enough in the air (lift required in my estimation) they will also come out the bottom. I don't have a lift...
Reviving an old post of mine from right after I bought the car.
I have had the car all apart over the winter for a head/cam/intake etc project. I don't remember how I got the fans out, I think my son did it.
Anyway, trying to get them back in form the top is impossible. I realize folks here say they will come out, but just don't see it unless yours is an older car with the ABS unit in the rear.
Re-read the shop manual....gee isn't that novel.... removed the sway bar mounts from the frame, dropped the swaybar down, and slid it in place. Total time to installed was 10 minutes with a smoke break.
I KNOW FOR A FACT,,, that the fans and bracket will come out from the top. Done it many times. Yea,, its tight and you have to do some wiggling but they will come iout from the top.
I have done it both ways top and bottom. My choice is drop the sway bar at the bushings and out drops the fan unit. I drive it up on the race ramps. Al so a lot easyer to deal with the wiring no fighting.
I also did a H/C project over the winter and removed/installed the fan + radiator assembly from the top (by myself). I also did a Vararam. With the lower shroud removed, the HVAC coils move farther forward to give much more clearance to the ABS module. Reassembly was a breeze, with a little time spent aligning the interlocking tabs. Good luck!
Just because you can do something does not mean that for you it is the best option. Last time I cleaned my radiator I did the move the sway bar out the bottom route and was comfortable that I was not putting anything else in danger. Also actually took the radiator out and cleaned it real well.
The other question that the OP asked was about trans cooler location.
Here are a couple pictures of how mine went. Nice mod - about 10-15 degrees less than coolant temps all the time.
Oh - the cheapest part is the cooler it self - look at another $100 or more for connectors and hoses to get it installed.
Pic 1 - top of radiator lines not attached shroud still off
Pic 2 - under the front lines around the side air dam & shroud still off
Pic 3 - shows new connections to "cut" stock lines
Nice job! Thanks.
I mounted mine on the other side, but it looks like we used the same cooler. Are you using the internal cooler as well? Or did you bypass it completely?
There is lots of discussion on this. I did the series thing.
So from the return of the built in cooler it goes up front to the extra cooler and then back to the tranny. The theory is that while we want temps that are not as high - we also do need it to be in the 150 range. If you bypass the stock one - you have nothing to heat up the trans fluid when it is cold. This may not be a Florida issue - but even the radiator has the thermostate on it so that the water in the engine gets hot faster before it opens.
Putting them in series is also the reason I put my cooler on the drivers side - so it did not block air flow to the stock cooler which is on the passenger side.
Finally you see two new hoses in pic 4 because I replaced the rubber line section that went into the stock cooler as over time rubber rots and those connections were shown to be the first point of failure in the stock setup. No rubber hoses on the car. Silicone coolent hoses - ss brake lines, and ss trans lines. Should be good to go for another 10 years!!!
While I was at it I added an almost free mod with an additional leaf screen in the front.
I figure the 3600 stall will help get the trans up to temp just fine. Also, Performabuilt requires the stock cooler to be bypassed for warranty purposes. Not too sure about that logic, but I have bypassed on all cars I've had with a stall and never an issue. I think either is fine.
