Im starting to run my vette in the 1/4 more frequently, and within the next few months the car will end up with a 3600 stall torque converter, so "hooking up" will now be an issue. I plan to buy a PAIR of rims to mount the slicks on, but I need a tire size. Any recommendations? Ill select the rims based of the tires y'all recommend me.
Also, kinda a shot in the dark, but what times do y'all reckon I should see close to?
3600 stall, slicks, 2.73s, a4, '97 LS1, everything else stock as well.
i run 255x50x16 hoosier dr's 18lbs air with 3600 stall and 3.73 gears with around 500 rw n/a my avatar shows a launch. you dont need slicks. good luck and get some gears
Do you have up graded drivetrain parts to complement those SLICKS???
The tires you have now are the FUSE that protect the rear and tranny.
If you install bigger fuses (STICKY TIRES), your liable to find out that the differential output shaft is now the smaller fuse.
BC
If you plan to run with slicks,you are going to start breaking pieces,esp if you have a manual trans. Sorry,Imissed that your have an A4,but broken drivetrain parts still apply.
