rear hub
Old Sep 25, 2011 | 03:57 PM
da1foxx's Avatar
da1foxx
Default rear hub
size of the bolt on the rear axel ,to remove the hub , any instructions on line
Old Sep 25, 2011 | 10:30 PM
hotmerc's Avatar
hotmerc
27mm sort of rings a bell, but its been a couple of years.
Old Sep 25, 2011 | 11:54 PM
da1foxx's Avatar
da1foxx
Default c5 hub nut
its a 33 mm nut , a deep well axel socket ., i finished the rear hub change , its not that hard , once you pull the spindal off the car leave the axel in , just unbolt it , bolt the other in
Old Sep 26, 2011 | 12:02 AM
cdkcorvette7's Avatar
cdkcorvette7
Old Sep 26, 2011 | 07:30 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yeah, 33mm nut on the axle but that won't get the hub off. Its held on from the rear by three torx bolts. I think they were T55 but please don't hold me to it.
Old Sep 26, 2011 | 02:01 PM
cdkcorvette7
Yup... mine were T55. Don't use power/pneumatic tools to remove these, they strip easily. Get a torx socket and hit them with a little PB Blaster if they are tough to get loose.
To rear hub
