Hard shifting into reverse
Old Sep 25, 2011 | 07:12 PM
bsalie99's Avatar
bsalie99
Default Hard shifting into reverse
I have a 2002 Z06 that has an LS3 swapped in. I have had 2 seperate times now that the transmission has refused to shift into reverse. I have to push with all my 280lb weight to get it to go into reverse. The other gears shift freely and the car drives fine. The car does have a aftermarket shifter in it that the previous owner put in, I dont know what type. The 2 times when this happened were after a day of autoxing, I dont know if that matters Do you guys think the shifter is messed up, or the tranny?
It does not make any difference if the car is running or not. The car has a Tex 0700 clutch installed new with the LS3 which has 2-3k miles on it
Any thoughts?
Old Sep 25, 2011 | 07:48 PM
Trios's Avatar
Trios
Do you have issues with getting it to go all the way to the right of the H pattern, or getting it to go up after it's all the way right? I ask because there is a reverse lockout solenoid that prevents you from moving the shifter all the way right when the car is moving forward, and if it's malfunctioning it could be causing this.
Old Sep 25, 2011 | 08:31 PM
bsalie99's Avatar
bsalie99
It wont go to the right, once into reverse it backs up fine
Old Sep 25, 2011 | 08:50 PM
TEXHAWK0's Avatar
TEXHAWK0
When mine does not go easily into reverse, I can usually drop it into a forward gear, then lightly engage the clutch, and go back to reverse.
I don't think I have ever had it not go into reverse after bumping the transmission a little.
Old Sep 25, 2011 | 08:59 PM
bsalie99's Avatar
bsalie99
Yea I tried that, it make no difference, If I can get it to the right it slips into gear, It must be the lock out, now How to fix it
Old Sep 25, 2011 | 09:59 PM
FLrealty's Avatar
FLrealty
replace the solenoid
Old May 13, 2012 | 10:40 PM
ScrapMaker's Avatar
ScrapMaker
Where can you access this solenoid to replace it?
Old May 14, 2012 | 12:37 AM
Trios's Avatar
Trios
To Hard shifting into reverse
