I need Help
Old Sep 25, 2011 | 09:41 PM
02*C5's Avatar
02*C5
Default I need Help
So I upgraded my tranny and a few other things. Well after putting this thing back together, I have been experiencing drivetrain vibration.
Now its not all the time. It is only present when the converter locks at 55MPH. It's bearable until 70 - 79 mph (the worst vibration) then at 80 mph it starts to go away.
Now I have ruled out the TT being bent because it only happens when its on cruise under load. I took some carb cleaner sprayed it around the whole manifold. I sprayed each injector and surrounding area to see if I had a vacuum leak up front and nothing.
So I am to my whits end. Any one can give me any advise let me know. I am so done right now I want to cry.
TIA
Old Sep 26, 2011 | 02:12 PM
FLrealty's Avatar
FLrealty
TIA
The guys at rpm are pretty cool and friendly. Give them a call I'll bet they can point you in the right direction.
Old Sep 26, 2011 | 07:02 PM
cdkcorvette7's Avatar
cdkcorvette7
what else did you do?
Any dtc codes present?
Old Sep 27, 2011 | 10:49 AM
02*C5's Avatar
02*C5
Added new bigger injectors and added bigger solenoids for a 175 nitrous hit. Added a different intake took vararam out and did a filter onto air bridge.
the DIC code are as follow:
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
This I know about because my MAF is out and I have a partial SD tune to limp around.
B2264 Vertical Position Sensor Fault
B2265 Vertical Position Sensor Fault
Those are for the doors so I have no idea why they would come on.
These are all the codes that are been thrown at the moment.
Old Sep 27, 2011 | 10:16 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
For a drive train vibration at speeds...when was the last time you had the tires balanced?
Old Sep 27, 2011 | 11:54 PM
lionelhutz's Avatar
lionelhutz
So, if you step on the brakes a little to keep the converter unlocked then it doesn't vibrate at all?
Do you need help learning how to post a descriptive title so you will get people looking at the thread and helping? Many people ignore "I need help" posts.
Peter
Old Sep 28, 2011 | 01:35 PM
02*C5's Avatar
02*C5
Its been a while but nothing has happened to throw them out of balance no curb hit or nothing.
Peter
Thanks for the advise will head warning next time.
at speed if it I hit the break it goes away or I push the gas to drop down to pick up a lower gear for passing it goes away. That's why I don't understand. Its just weird like I said between 55-69 its ok 70-79 I want to drive the car into a wall because it bothers me once i hit 80mph again its like it goes away.
Yet when am in neutral or slowing down it goes away. That's why i know its not the TT being bent or anything being bent for that matter. I think I am going ot have to bite the bullet and take the whole thing apart again and see what the hell is going on. Dam it.
Old Sep 29, 2011 | 04:13 PM
cptinjak's Avatar
cptinjak
If you had the trans out, you had the wheels off. Double and triple check that the wheels are centered on the hub, and torque them properly. It's very easy to get a wheel on slightly wrong, or it might even be an alignment issue. Clean up the hub-wheel surfaces, (wire brush the rust off, etc) and have the tires re-balanced, and get an alignment. I tell every person whose car I work on that they need to get re-aligned if I had the driveline out. No exceptions.
If you don't verify FOR SURE that all the above is in proper order, any further diagnosis you receive from the forum might as well be a shot in the dark.
IF all the above things I mentioned are squared away, I would begin by checking torque tube bushings/bearings. you dont necessarily have to bend something to get a little wobble out of the TT. Bushings degrade over time, and a friend of mine just had his front bearing let go and took out all sorts of clutch/slave/pp with it.
Also, who did the transmission work? It could be that you're getting an odd vibration due to insufficient preload, or excessive endplay on the mainshaft, but it would have to be WAY wrong to feel it like you're describing.
Jack
Old Sep 29, 2011 | 06:50 PM
lionelhutz's Avatar
lionelhutz
To me, the vibration changing due to engine rpm and torque converter lock-up, and not due to the speed, would point to a problem with the torque-tube or the converter. Basically something on the input side of the trans and not the output side.
I know there is some type of procedure for aligning/adjusting the torque tube on an auto. Did you do that?
The engine could be doing it if it had a miss, but I'd think you're at a high enough rpm that it wouldn't really cause a vibration and you'd likely know if it was missing at idle or at a lower rpm when the converter is locked. An engine problem should be the worst at the lowest speed where the converter would lock, say around 50 or 55mph in OD.
Peter
To I need Help
