Special LED flasher modules to eliminate hyperflash
Old Sep 26, 2011 | 03:42 PM
TrueBlueCoupe's Avatar
TrueBlueCoupe
Default Special LED flasher modules to eliminate hyperflash
Anyone tried the special LED flasher module in their C5 to eliminate hyperflash? If they work I find this a much more appealing solution than a special harness or resistors.
Here is the link to the flasher modules
http://autolumination.com/equalizers.htm
Old Sep 26, 2011 | 05:04 PM
mdiiulio's Avatar
mdiiulio
Are you experiencing hyper-flash right now? I just installed new LED tails in my '04 coupe and have only experienced hyper-flash while the car was off (testing the install). Once I got it up and running the lights were good to go. I've heard of other forum members experiencing this also... Luck of the draw I guess
Old Sep 26, 2011 | 05:25 PM
TrueBlueCoupe
I have not made the move yet to order the Switchback DRL bulbs yet due to the fact I really do not want to add a special harness or resistors. My hope is that I would not have the problem either, but if I did I wanted to have a plan in place and a special flasher that will work with regular or led bulbs would be great and you would never have to worry about it again.
Old Sep 26, 2011 | 07:19 PM
Arnie Chamberlain's Avatar
Arnie Chamberlain
You don't need a special harness. The $11 Autozone heavy duty flasher works just fine.
Remove the radio surround and knee bolster on the drivers side. Unplug the harness leading up to the hazard switch. Depin the pink and purple wires from the chassis side of the harness. Make yourself a few pigtails that connect from the harness to the new flasher. Plug the new flasher into the chassis wires you just depinned. PINK goes to the B terminal on the flasher, PURPLE goes to the L terminal on the flasher.
Test it before reassembling the car. Cost is just the cost of the flasher, some terminals and wire if you don't have them around. No-cut, no permanent mods, saves you $40+ to go for gas or taco bell.
Old Sep 26, 2011 | 09:32 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Those you would need to wire in. We have a no cutting solution available. They'll be back in stock later this week
http://shop.jwmotoring.com/product.s...2&categoryId=4
Old Sep 26, 2011 | 10:12 PM
Baldfart's Avatar
Baldfart
Good! I've been watching you're site to see when you get them in.
Old Sep 26, 2011 | 10:29 PM
lionelhutz's Avatar
lionelhutz
They're no good. The C5 flasher is part of the hazard switch.
I recommend you install a flasher bypass harness. Then the hazard/flasher won't act up and leave you with intermittent signals one day.
Peter
Old Sep 27, 2011 | 09:33 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
This sounds like a great alternative solution!
Can you add a few pics into your write-up?
Old Feb 6, 2013 | 07:57 PM
SSTG's Avatar
SSTG
I know, old thread...
But has anyone done this? Is there a write up? Or better yet, does anyone know where to get the connectors to make our own?
Old Feb 6, 2013 | 08:34 PM
Arnie Chamberlain
I did it, worked fine so far for 18 months and 10k miles and no reason it wont continue to work fine. What additional steps would you like in a write-up?
Old Feb 6, 2013 | 09:47 PM
c5mtl's Avatar
c5mtl
THX for the short write up...ive got one of these relays on its way from fleebay.....as far as the vendors go....i understand they have a business to run but 50-60$ is a little high for a 5$ relay and some wire
Old Feb 6, 2013 | 10:03 PM
Quicksilver Vert 01
Your write-up is pretty straight forward, but a few pics would be helpful too.
Old Feb 6, 2013 | 11:02 PM
SSTG's Avatar
SSTG
Thanks Arnie.
I assume T-taps wouldn't work since it would still be going thru the stock flasher? But IF I can get the wires removed from the molex connector I can reinsert and make it stock again.
Also, I seen people use two and three pin connectors, is one better over the other?
Old Feb 7, 2013 | 03:02 PM
SSTG's Avatar
SSTG
Bump.
Old Feb 8, 2013 | 02:35 AM
c5mtl's Avatar
c5mtl
just to add....if anybody ends up buying a 3 pin relay the 3rd (e-pin) ends up on ground ....all kinds of grounding locations near there.
im asuming that the pink and purple wire on the other side of the harness just stay blank.....i hope cause that how i left mine...seems to work ok
Old Feb 8, 2013 | 08:46 AM
SSTG's Avatar
SSTG
I read in another post there is a "Black" wire in the bundle that is a ground?
Old Feb 8, 2013 | 12:08 PM
c5mtl's Avatar
c5mtl
I just grounded it to a bolt that was near by
To Special LED flasher modules to eliminate hyperflash
Old Feb 8, 2013 | 04:01 PM
SSTG's Avatar
SSTG
I also see some just use a two wire relay...
One better than the other?
http://forums.corvetteforum.com/c5-t...with-leds.html
Old Feb 8, 2013 | 08:10 PM
c5mtl's Avatar
c5mtl
i think the flasher he used is not available anymore...what puzzles me is he said dont cut the pink wire....wonder if what i did created any negative effect
Old Feb 8, 2013 | 08:17 PM
lionelhutz's Avatar
lionelhutz
Cut it, it doesn't matter. For some reason, I believe I was thinking it powered the hazards too but there is another non-switched feed for the hazards.
