Found this out when I attempted to remove the links to replace the rear bar. Had to go to the store to get the correct torx size and ended up rounding off the torx stud. I need to get new links so I can remove the link from the other end and replace all the links.
I'm guessing Peter is correct. I'll know in a couple of days as I just ordered all four and they are on their way to me now.
Peter is correct about that.
The front links are a little more difficult to replace, due to the limited clearance near the links. I recommend using a ratcheting box wrench on the nuts, preferably one with a flex head, to make things easier. Also use the same size Torx bit, as on the rears, to keep the stud from turning.
There are also flats on the boot-side of the links to get a regular 18mm open-end wrench in there. The C6Z51 sway bars went on real easy with two choices to prevent spinning the shaft. It let me use the torque wrench, too.
