wheel fitment??
wheel fitment??
Hi there guys. Would the following setup fit nicely on a C5 coupe? More interested in how the offset, center bore, and bolt pattern would be than the size of the wheels.
Size: 20x9 front and 20x10.5 rear
Bolt Pattern: 5 x 120
Offset:35mm front and 45mm rear
Center Bore : 72.56mm
I wouldn't do it... they'll stick out too far with those offsets. Also, you'd probably be better of with a 19X20 combo instead of 20X20. With 20's on the fronts and backs you're going to have to find a rubber band to stretch around the fronts to keep your AH/TC system happy. The rear wheels have to be taller than the fronts by AT LEAST .5 inches. I think the stock height difference is 1.1 inches..
those wheels were on a '09 CTS-V. The guy told me they would fit on a C5 as well. I just wanted to double check. I appreciate everyone's input. Thanks guys!
