outside air temp. sensor???
Old Sep 30, 2011 | 10:40 PM
NearlyGone85's Avatar
NearlyGone85
Default outside air temp. sensor???
My dad has a 2000 coupe and his outside air temperture sensor is going crazy. It probably just doesnt believe it is really 119 outside
ifthe air conditioner is on, the outside air temp will go down to around 50 degrees. does anyone know where this sensor is so i can replace it? or has anyone had this issue and know of any kind of fix?
thanks!!!
Old Sep 30, 2011 | 11:32 PM
8VETTE7's Avatar
8VETTE7
thanks!!!
Sensor is on the passenger side. It is at the right hand corner of the front most part of the lower radiator support. More easily seen from under the car. Single electrical connector goes onto the back side of the sensor. Sensor is called "ambient air sensor".
Old Oct 1, 2011 | 01:35 AM
Chicago1's Avatar
Chicago1
Also Its like 12 bucks at the dealer I believe.
Old Oct 2, 2011 | 10:32 AM
NearlyGone85
Oh man! Thank you so much!
Old Oct 2, 2011 | 01:38 PM
flynhi's Avatar
flynhi
The new sensor will not immediately record accurate temp. The HVAC module takes a while to "learn". In my case, it was about 20 min of driving.
Also, FWIW, my 99 works best in Man mode. Cannot explain why.
Old Feb 7, 2012 | 06:01 PM
rcoughenour's Avatar
rcoughenour
Can anyone tell me how to get the Outside air sensor out of it's little hiding place ? I see there is a screwbut not sure if it is supposed to be screwed out or just popped out by prying it with the screw driver. ?Not a lot of working room in there.
Old Feb 7, 2012 | 06:20 PM
rcoughenour
Ok I started to use my brain and figured it out, Duh it is plastic and the mount is plastic, plastic screw, It preys very easiley....Thanks
Old Feb 7, 2012 | 06:33 PM
stupid fast Z06's Avatar
stupid fast Z06
with hood open you just reach down and pull it loose.
Old Feb 7, 2012 | 07:16 PM
Baldfart's Avatar
Baldfart
thanks!!!
Just wait a few more months and it will be right!! Here in Arizona!
Old Feb 8, 2012 | 05:25 PM
BLUE Y2K's Avatar
BLUE Y2K
The connector for the little buggers get corroded to. Make sure that you clean it before installing the new one. A poor connection will send faulty signals giving you an inaccurate reading. Good Luck!
Old Aug 11, 2013 | 11:38 PM
pawngod's Avatar
pawngod
subscribing, thanks
Old Aug 11, 2013 | 11:54 PM
Chicago1's Avatar
Chicago1
edit: nevermind
Old Aug 12, 2013 | 12:01 AM
Vette_DD's Avatar
Vette_DD
Originally Posted by Chicago1
Just fyi if you go to "thread tools" there is a option to subscribe to a thread" that way you aren't bumping a 18 month old post that will probably get locked, Just a friendly tip..
No longer against the rules. Announcement made about 2 months ago about rules changes.
To outside air temp. sensor???
