Squeaking aftermarket harmonic balancer
Old Oct 1, 2011 | 10:02 PM
mustangracer's Avatar
mustangracer
Default Squeaking aftermarket harmonic balancer
I've been having a squeaking problem and has finally pissed me off. I pulled off the belts one at a time and neither of them, so I start with nothing and it's still squeaking therefore leaving the balancer as the culprit. Now the catch, it's an aftermarket auto specialties performance balancer. It does not wobble or anything of the nature, does anyone have any way to fix this that doesn't require dropping the cradle or buying new parts.
Old Oct 1, 2011 | 10:51 PM
cdkcorvette7's Avatar
cdkcorvette7
Have you verified that it's the balancer with a stethoscope? If it is I think your looking at replacing it...
Old Oct 2, 2011 | 02:17 AM
lucky131969's Avatar
lucky131969
To be clear. The balancer is not wobbling, or separating. You removed both belts, and still have a squeaking noise, so you have concluded it is the balancer??
Old Oct 2, 2011 | 02:45 AM
mustangracer
removed both belts and squeaking is still there, and no it is not wobbling/moving at all.
Old Oct 2, 2011 | 04:39 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
What installation guide did you use? Di you use the OEM TTY bolt or an aftermarket multi-use type.
Old Oct 2, 2011 | 01:49 PM
mustangracer
I honestly have no idea, it came on the car almost 2 years ago
Old Oct 2, 2011 | 01:57 PM
00Corvette's Avatar
00Corvette
The only thing the balancer should be MAYBE touching is the timing cover seal??
Old Oct 2, 2011 | 03:41 PM
lup302's Avatar
lup302
had the same prolbem with the same brand name damper swapped out with ATI no more noise.
Old Oct 2, 2011 | 08:35 PM
mustangracer
lup302 any ideas what was causing the noise?
To Squeaking aftermarket harmonic balancer
