Engine misfire on acceleration!
Old Oct 2, 2011 | 04:00 PM
sfc rick's Avatar
sfc rick
Default Engine misfire on acceleration!
Just started a week or two ago, would misfire under acceleration but when the pedal was released and applied again it would be fine. This started ever so often, not consistently. But it now happens more frequently, still depends on how hard the gas pedal is applied and reapplied.
No codes, no vacuum leaks, maybe Throttle position sensor?
Has anyone ran into this before?
Old Oct 2, 2011 | 05:50 PM
LoneStarFRC's Avatar
LoneStarFRC
Carefully follow your injector wiring harness (both sides) where they go to the rear of the manifold and makes a turn around the fuel rail stop bracket.
Tight fight + engine vibration/movement = 1 or more wires being rubbed through and intermittent shorting of an injector. Check your coil wiring harnesses as well.
Give it the close eyeball. The slightest little cut is all it takes.
HTH
Old Oct 2, 2011 | 06:13 PM
sfc rick's Avatar
sfc rick
Will give it a look! I certainly have been doing a lot of work on the top end and could've done something. The start of many problems have been the result of fixing others.
Old Oct 2, 2011 | 07:15 PM
LoneStarFRC
I'll definitely agree with you there.
Old Oct 2, 2011 | 08:02 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
And you pulled the codes using the DIC?
Old Oct 2, 2011 | 08:38 PM
sfc rick's Avatar
sfc rick
No codes
Old Oct 2, 2011 | 10:01 PM
dgrant3830's Avatar
dgrant3830
If the misfire was related to the throttle position sensor, I would expect it would throw a TCS code(s). I'm sort of wondering if you have a grounding issue with the fuel pump itself as it has its own ground. Another quick thought would be a sticking throttle plate.
Old Oct 2, 2011 | 11:26 PM
sfc rick's Avatar
sfc rick
I also would have expected a code for a tps or misfire if a coil was out, but alas no codes.
I'll work on the car in the morning.
Old Oct 3, 2011 | 02:14 PM
sfc rick's Avatar
sfc rick
Found the problem, a sparkplug wire was jumping to the header pipe on the right of the dipstick tube. Really couldn't find a way to put more space between them, so I cleaned the sparkplug boot and brushed on some liquid tape. No miss now, but it's only a.temporary fix until I buy new sparkplug wires or find a better solution.
Old Oct 3, 2011 | 02:21 PM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
Glad to here you found the problem. The car will act the same way if one of the coil packs are going bad. They will misfire under load (acceleration) but be perfect under idle. Good Catch.
Old Oct 3, 2011 | 02:44 PM
Tech's Avatar
Tech
If they are MSD wires and low mileage, I can send you a used wire to replace the defective wire. I think mine have about 15k on them. I burned one and had to buy a whole new set. Now I have 7 spares.
Old Oct 3, 2011 | 02:58 PM
sfc rick's Avatar
sfc rick
PM sent
Old Oct 3, 2011 | 03:17 PM
Tech's Avatar
Tech
Replied
Old Oct 3, 2011 | 03:49 PM
redrckt97's Avatar
redrckt97
wouldn't the Koolsox or similar brand wire cover help/prevent this?
Old Oct 3, 2011 | 04:37 PM
Tech's Avatar
Tech
They do. However, they are unnecessary and, in my personal opinion, ugly.
MSD wires have an end that will allow you to bend/shape them away from hot parts. I apparently missed double checking my wires after doing some work one day. I imagine the OP had a similar situation.
Old Oct 3, 2011 | 04:49 PM
sfc rick's Avatar
sfc rick
Better Solution!
I found my oil dipstick tube was pushing the sparkplug boot onto the header pipe. I noticed the notch for the dipstick on the cover was further over so I pushed the dipstick tube over to the notch. It made plenty of room.
Old Oct 3, 2011 | 06:43 PM
LoneStarFRC
Consider this quality, bonding-time with your car.
Old Oct 3, 2011 | 07:19 PM
sfc rick's Avatar
sfc rick
I bonded my finger to it.
To Engine misfire on acceleration!
