Can I mix heads?
Old Oct 3, 2011 | 11:47 PM
futuretech's Avatar
futuretech
Default Can I mix heads?
I am replacing 243 head with steel valves. I see another for sale the is the genuine Z06 head with sodium valves. Can I have steel valves on one side and sodium on the other ?
Old Oct 4, 2011 | 06:37 AM
baxsom's Avatar
baxsom
the valves are a different length. you would need longer pushrods in the steel valve side.
you can use both of the heads but one would need a valve replacement. btw the genuine z06 heads in a 01 LS6 motor didnt have sodium valves either.
Old Oct 4, 2011 | 07:23 AM
AU N EGL's Avatar
AU N EGL
for anything above 6500 rpms you want the sodium and hollow valves and the appropriate springs to prevent valve float
Old Oct 4, 2011 | 10:41 AM
futuretech's Avatar
futuretech
NOw that makes sense. Keep it the same! Thanks.
To Can I mix heads?
