Head bolt question
Old Oct 4, 2011 | 12:50 PM
TheDEfan's Avatar
TheDEfan
Default Head bolt question
I putting mine back togeather after a lifter swap, and I over turned the first bolt by mistake. I went like a 180 degrees instead of 90 because my batteries were low on my Torque wrench and it diden't beep at me, so I backed it out. Should I replace the 1 bolt or am I ok to reuse it?
Old Oct 4, 2011 | 01:07 PM
TrueBlueCoupe's Avatar
TrueBlueCoupe
Replace it!!! do not take any chances on head bolts, if it breaks it will destroy more than you can imagine!
Old Oct 4, 2011 | 01:59 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yes, I agree with replacing it but the torque sequence and settings, the first pass only is done to FtLbs of torque. The remaining turns are all done by "degrees" and the last pass is extremely difficult. So the question comes, at which part of the sequence did you turn it a full 180 deg?
Old Oct 4, 2011 | 02:00 PM
TheDEfan's Avatar
TheDEfan
That's what I thought, cheep insurance, what about the head gasket?
Old Oct 4, 2011 | 02:05 PM
TheDEfan's Avatar
TheDEfan
Went to 22ft lbs first on all of them. then 180 or so on the first bolt only. It should have been 90.
Old Oct 4, 2011 | 04:49 PM
SaberD's Avatar
SaberD
Did you use oem bolts or ARP? I think the ARP ones can be reused.
Old Oct 4, 2011 | 05:13 PM
dgrant3830's Avatar
dgrant3830
So did you stop there or continue? Question is in regards that if you stopped there, now the head is not down properly at that point. I tend to doubt you warped it. Depends on where you stopped the process and what the status is now. As stated, if you used ARP bolts, no issue, but OEM, then personally speaking, at that second turn, you are turning in degrees, not waiting for a beep from a torque wrench. The implication is that you were torquing to FtLbs instead of degrees which is wrong therefore you won't know what the final turn should be.
Old Oct 4, 2011 | 06:22 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
No bolt can be re-used when taken past its elastic limit and yield point during tightning, regardless of the manufacturer.
Perhaps you should read up on fastener tensioning before making incorrect recommendations like this one.
Old Oct 4, 2011 | 06:30 PM
TheDEfan's Avatar
TheDEfan
I stopped there, I knew I screwed up. I'm picking up new bolts tonight and pulling the head off and running a stright edge across it just to be sure. I was useing an degee torque wrench. I'm a mobile tool dealer. I have lots of tools, just not sure how they work sometimes.
To Head bolt question
