No Start - New Owner
Old Oct 5, 2011 | 03:37 PM
piran21's Avatar
piran21
Default No Start - New Owner
Hi guys,
This wasn't the way I was planning to introduce myself to the Corvetteforum. I just purchase an 02 MY Corvette Coupe 6spd last week. Been great so far until this morning on the way to work. Leaving my house, it started fine and I drove it nearby work to grab some coffee. When I went to restart the car, I got nothing. Ignition turns on fine, no codes flash, battery was replaced, fuel pump primes. Nothing happens. I had no choice but to leave the car where it was and get a friend to pick me up. Can anyone offer any guidance?
Thanks,
Piran
Old Oct 5, 2011 | 04:11 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
clutch ignition switch?
Old Oct 5, 2011 | 05:59 PM
cdkcorvette7's Avatar
cdkcorvette7
Originally Posted by piran21
Hi guys,
Thanks,
Piran
Well no codes present always makes it a fun guessing game...
The next time that happens take a long screwdriver and tap on the starter. If it starts after that there's a good chance your starter solenoid is shot. That happens pretty often on these cars because of it's proximity to the headers which give off a lot of heat.
The other thing you might try is pulling your ignition switch and cleaning the contacts. Bill Curlee has a great thread on that. Let me know if you can't find it...
Old Oct 5, 2011 | 10:22 PM
cor28vettes's Avatar
cor28vettes
Default solenoid in my case
http://forums.corvetteforum.com/show....php?t=2925332
Old Oct 5, 2011 | 11:37 PM
piran21's Avatar
piran21
Thanks for responding to my post. Had to tow the car. I found a No-start troubleshooting doc for the C5. Checked over the TDR etc. Works fine. Cleaned the connectors to the starter. No dice. There is power coming to the starter solenoid but no cranking at all. Tapping/knocking on the starter while turning the ignition didnt result in anything. Still no start. I am going to replace the starter or get it rebuilt.
Any objections?
Thanks,
Piran
Old Oct 5, 2011 | 11:51 PM
cdkcorvette7
Any objections?
Thanks,
Piran
If you haven't pulled the ignition switch and cleaned the contacts I would do that first. Tapping on the starter probably would have allowed you to start your car if that's what the problem was...
Old Oct 6, 2011 | 12:13 AM
piran21's Avatar
piran21
even with the power getting to the starter solenoid, the ignition could still be the potential culprit?
Old Oct 6, 2011 | 12:22 AM
cdkcorvette7
Oops... Missed that part of your post. If you're getting power to the starter and it's still not cranking then I'd say you've found your problem...
Old Oct 6, 2011 | 08:32 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yeah, I agree. If you close the TDR and the starter doesn't at least click, then your solenoid is done. Possible wire from the TDR to the solenoid but that would be rare.
Old Oct 8, 2011 | 12:19 PM
piran21's Avatar
piran21
it was the starter solenoid. thanks guys!
To No Start - New Owner
