Bypass TPS module???
Old Oct 5, 2011 | 04:46 PM
427TTA4's Avatar
427TTA4
Default Bypass TPS module???
Starting off i have bought some oem c6 z06 wheels for my c5 I dont know what people say about fit ment issues mine fit perfect(305 tire in the R).Any how they dont have the tps modules in them and my dic keeps on saying "service tire pressure monitoring system" I know its because of the tps sensors not being installed.My question is...is their anyway to bypass them or the monitoring system for the mean time?I will in the next few months replace them but its just that message keeps on beeping and coming up.Thanks for looking
Old Oct 5, 2011 | 04:50 PM
dougbfresh's Avatar
dougbfresh
No bypassing them, the later models can be tuned out.
Old Oct 5, 2011 | 04:54 PM
doveboat's Avatar
doveboat
The C5Z does not have this enabled from the factory, but I understand that it can be enabled if you added sensors later.
Is it possible to reverse the process and "un" enable it with a Tech 2 ?
Also, did you buy C5Z wheels for your C5 ? A C6Z rear wheel would have larger than a 305 and probably come with a TPM sensor.
Ed
Old Oct 5, 2011 | 05:01 PM
427TTA4's Avatar
427TTA4
Nope they are c6 z06 but sorry they are not oem they are repos but are in fact 19x12.I bought them like that though who ever had them before didnt install them so thats why im in this position lol ill post pics though.Also my car is a 99 Z51 M6 I dont know if it matters.
Old Oct 5, 2011 | 05:07 PM
427TTA4's Avatar
427TTA4
yep here they are
Old Oct 5, 2011 | 05:08 PM
dougbfresh's Avatar
dougbfresh
The C5Z had non-runflats from the factory so the TPMS was disabled from the factory. Do a search on this but until the Z came out, it was not possible to turn this off with swapping things inside the car. Many just put the sensor inside the wheel with a band to hold it in place.
Old Oct 5, 2011 | 05:39 PM
427TTA4's Avatar
427TTA4
I dont quite get you.Like inside the wheel where you can still see it???Or actually inside between the tire and rim???
Old Oct 5, 2011 | 07:26 PM
Arnie Chamberlain's Avatar
Arnie Chamberlain
You can tire pressure monitors on OR off with a Tech II on 2001 and later. Its a 5 minute job and completely reversible.
Old Oct 5, 2011 | 08:00 PM
jrose7004's Avatar
jrose7004
I would have put the sensors on with bands myself.
Old Oct 5, 2011 | 09:15 PM
Bill Dearborn's Avatar
Bill Dearborn
C6Z repro wheels can still mount tire pressure sensors in the correct way and there is no need to band them to the inside of the wheel barrels. Why not just buy some C5 sensors for your car and install them in these wheels? Then use a magnet to program the car to recognize them.
Since this message only occurs whenever you start the engine why not just hit the reset button and get rid of the message? A lot easier than doing anything else.
Bill
Old Oct 6, 2011 | 01:35 AM
C5Natie's Avatar
C5Natie
I just hit the reset button....every startup. Lol. You get used to it. Seat belt, reset button, tc off
Old Nov 23, 2011 | 05:38 PM
Eric Fischer's Avatar
Eric Fischer
Originally Posted by 8VETTE7
You have 3 choices on the 1997 - 2000 vintage cars:
2) Install the 1997 - 2000 sensors and train them so the error do not appear.
Pick a choice.......
Here's more detail on choice 2:
||--Genuine GM 97-00 Corvette to 01-04 Corvette TPMS Conversion--||
PKC5TPMS - $395.00 (Special Discounted Price)
This kit includes the following:
(1) #1 Key FOB
(1) #2 Key FOB
(1) Remote Control Door Lock Receiver
(1) Remote Control Door Lock Receiver Connector
(4) Tire Pressure Monitoring Sensors (TPMS)
(4) Tire Pressure Monitoring Sensor Mounting Nuts
This kit retails for $669.23 and includes everything you need to convert your TPMS and key FOB’s in your 1997-2000 Corvette to the 2001-2004 Corvette. This is done to change the future costs or current costs of the more expensive 1997-2000 Corvette TPMS and key FOB’s to the lesser expensive 2001-2004 Corvette TPMS and key FOB’s. Click on the link below to purchase.
http://store.gmpartshouse.com/partlo...catalogid=8669
To Bypass TPS module???
