2000 gauge cluster
Old Oct 6, 2011 | 12:17 PM
mjoacim's Avatar
mjoacim
Default 2000 gauge cluster
If I replace my entire gauge cluster with one from another car, is the mileage stored in the computer and will appear correct on the new cluster or is that something that the cluster stores? I don't want to be accused of odometer fraud. My title states more mileage than the car that the new cluster came out of. I know someone will ask so, the only reason I'm considering replacing the cluster is because I access to one out of a Z06 that has upgraded needles, faces and LED's behind.
Thanks,
Mike
Old Oct 6, 2011 | 12:31 PM
87SAM's Avatar
87SAM
This may help.
http://forums.corvetteforum.com/c5-t...enter-dic.html
Old Oct 6, 2011 | 12:36 PM
mjoacim's Avatar
mjoacim
Thanks 87SAM!!! That should do the trick for me!
Old Oct 7, 2011 | 12:34 AM
68Bullitt's Avatar
68Bullitt
Thanks,
Mike
The mileage is stored in the cluster. If you move a cluster from another car, the mileage on that cluster will display. You can swap the main circuit board from your old cluster to the new one and the mileage will follow. It is an easy swap. Probably a half hour with both clusters out of the car.
To 2000 gauge cluster
