Headers or gears
Old Oct 6, 2011 | 03:34 PM
Doug O's Avatar
Doug O
Default Headers or gears
I have a 2001 A4 vert. She is perty much stock. Upgrads are K&N cia , Billy boat prts, and a mail tune by ECS. Presently the gears are 2:73 s if I have them changed I will go with 3:42 s . Cost about 1400.00 . How much will the gear change affect mpg ? Or have long tub headers with high flow cats installed. The headers should not affect mpg , I don't think. Cost 2100.00 . I'm looking for the car to perform better than it dose now. Which is a better bang for my dollor.
Doug O
Old Oct 6, 2011 | 03:43 PM
chaase's Avatar
chaase
St. Jude Donor '12
Gears will be the best bang for the buck since you have 2.73's. The gear change will have a slight negative affect on fuel economy, but I can't say how much.
scott1974's Avatar
scott1974
gears
Old Oct 6, 2011 | 03:51 PM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
Gears without a doubt! May be a 2 mpg drop. With my mods (342 from 273, 3000 stall, cam, vararam, Long tubes, high flows,) I lost 3 mpgs
Old Oct 6, 2011 | 05:09 PM
cdkcorvette7's Avatar
cdkcorvette7
+1 for gears
Old Oct 6, 2011 | 05:46 PM
turbolvr321's Avatar
turbolvr321
Gears.
Old Oct 6, 2011 | 07:28 PM
orth_98vette's Avatar
orth_98vette
darn maybe i need to get some gears.. i know that lg tbs put like almost 30 to the wheels with a tune.. that's power you can feel.. but i hear you can feel gears to..
Old Oct 6, 2011 | 07:42 PM
Bluefire's Avatar
Bluefire
Technically, yes and no.
Headers will add ~30 rwhp but remenber, hp is only the potential to do work. They may improve gas mileage 1 - 2 mpg.
Gears are increasing the mechanical gain. this directly relates to more being work done. Something your butt immediately feels. You will loose maybe 1 - 2 mpg with the 3:42's
I have done both mods at different times. I definitely noticed the gears more in my butt dyno.
Old Oct 6, 2011 | 07:48 PM
orth_98vette
good stuff.. that will be the next thing for me.. i have a 98 what gears are stock?
Old Oct 6, 2011 | 08:18 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Exhaust, CAI, gears, headers, cam, heads seems like a logical order.
Old Oct 6, 2011 | 10:16 PM
mitchell c's Avatar
mitchell c
Do it right the first time. While your car is apart also install a high stall converter to go along with your 3.42 or 3.73 gears. Excluding NOS a high stall conveter gives the biggest bang for the buck on an A4. The Yank SS3200 or SS3600 are great choices and have excellent street manners.
Old Oct 6, 2011 | 10:21 PM
mitchell c's Avatar
mitchell c
2.73 gears are standard on A4s with 3.15 being optional. Check inside your glove compartment check the tag if G92 is listed you have 3.15 gears. Or drive 75 mph in 3rd gear if your tach reads 3150 rpm you have 3.15 gears if it 2730 you have 2.73s.
Old Oct 6, 2011 | 10:24 PM
orth_98vette
damn that's some good info dude..
Old Oct 6, 2011 | 10:48 PM
robert123's Avatar
robert123
I just brought a used set of SLP headers with pipes, high flow cats, all the way to the catback for 450.00 . I will do the install myself. I am not sure I would do gear install myself. For me, headers are THE BEST BANG FOR THE BUCK and they will sound great too. What do you guys think?
Old Oct 7, 2011 | 02:56 AM
orth_98vette
hope you know when you install the right or left header your going to have to loosen up the engine bolt.. not to much just a little... it was a fun time.. when we hooked up the off road x pipe and the borla straight pipe we got a ticket 5 min later.. loll. it's all good....
Old Oct 7, 2011 | 08:42 AM
mitchell c's Avatar
mitchell c
I see in your profile you have an M6 not an A4. 3.42 gears are standard on M6 cars. Sorry for the mix up.
Old Oct 7, 2011 | 09:01 AM
Thickraybans's Avatar
Thickraybans
If you're paying someone to do the work, having the gears,converter, & exhaust done all at once will probably save you enough on labor, to cover most of (if not all) the cost of a tune. Some shops will discount the parts if you do multiple mods all at once. The exhaust will have to be partially disassembled to do gears anyway.
To Headers or gears
Old Oct 7, 2011 | 12:00 PM
Doug O's Avatar
Doug O
Thanks everyone for the info. I think I could live with loosing 1 to 2 mpg if the car has quicker pick up. Out of curosity what is the big deal with a stall converter. Other than headers I do not plan to do to much else.
Doug O
Old Oct 7, 2011 | 12:04 PM
Doug O's Avatar
Doug O
Forgot . I live in the Harrisburg Pa. area . Anyone know a good shop to get the gears work done.
Doug O
Old Oct 7, 2011 | 12:06 PM
chaase's Avatar
chaase
St. Jude Donor '12
I am not sure I will explain it correctly but it basically lets the engine spin a bit more before becoming fully engaged. The car will launch harder and be more responsive on down shifts.
