Headers or gears
Old Oct 7, 2011 | 12:06 PM
docbrew's Avatar
docbrew
+1 on gears and TC. I did this mod last summer and its been great.
Old Oct 7, 2011 | 12:12 PM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
You don't have to go to a stall converter with 3:42's. I have in excess of 420 to the wheels and the stock converter. Been doing that for 3 years and 50K miles with out any problems. Changing the gears is a great bang for the buck. You will wonder where the car you are driving came from.
Old Oct 7, 2011 | 12:16 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Originally Posted by Doug O
Forgot . I live in the Harrisburg Pa. area . Anyone know a good shop to get the gears work done.
Doug O
If you have 2.73s you will want to upgrade the entire carrier which will have 3.42s already. Then you just need to find someone who can switch carriers and someone to change the shift points.
Old Oct 7, 2011 | 01:19 PM
08 ATOMIC-Z
To save heartache later just get a new one. You are taking a big chance buying used. New Pumpkins cost more but it is money well spent.
Old Oct 7, 2011 | 02:26 PM
craig04c5's Avatar
craig04c5
Definitely gears!
Old Oct 7, 2011 | 04:54 PM
PRE-Z06's Avatar
PRE-Z06
Gears will be a better bang for the buck and you will only loose mpg on the higway as you will gain torque multiplication for accelerating the car more easily around town. Rick@RKT56 is a sponsor here, just moved to Maryland and should be able to get you taken care of on the gear swap.
Old Oct 7, 2011 | 05:09 PM
had2have-it's Avatar
had2have-it
If you think you might do both eventually, do headers first, then the improvement in actual power output will let you know how radical (or not) your gearing should be. If you're sure its one or the other only, do the gears.
Old Oct 7, 2011 | 05:18 PM
mitchell c's Avatar
mitchell c
Thanks everyone for the info. I think I could live with loosing 1 to 2 mpg if the car has quicker pick up. Out of curosity what is the big deal with a stall converter. Other than headers I do not plan to do to much else.
Doug O
The stock converter stalls at about 1300 rpm. For example a Yank ss3600 stalls at 3600. Your engine produces alot more power at 3600 than it does at 1300 rpm. A high stall t/c allows your engine to spool up instantly to a higher RPM where it is making much more power. It also gives you higher shift extention, meaning when your tranny shifts at WOT your rpm does not drop as low between shifts. When your tranny shifts at WOT a converter like an SS3600 will only allow your engine drop to about 4800 rpm. The stock converter will be about 3800 rpm. And no you don't have to rev your engine to 3600 to get your car to move. The SS series Yanks are tight converters and feel alot like the stock converter when you are driving normally. I hope this helps.
Old Oct 8, 2011 | 07:45 PM
Bluefire's Avatar
Bluefire
Doug O
One main reason to consider adding a stall is if you decide later to install a cam. Anything larger than a mild cam will require a certain amount of that "extra slip" a stall offers to allow the car to not "creep" much at the higher idles speeds a bigger cam needs to stay running.
Old Oct 13, 2011 | 05:49 PM
67ermine's Avatar
67ermine
I put a vararam CAI and headers with high flo cats, x-pipe, and tune MPG was as high as 32 on highway. Then put in 3.42 gears and a small cam , MPG fell to 27 Was it worth it? Oh heck yeah! 373rwhp 369tq
As mentioned, be sure to put in at least a yank 3200 stall. Keep an eye on trans temp while in traffic- it may need a trans cooler.
