Good compression?
Old Oct 6, 2011 | 09:47 PM
Vicarious.'s Avatar
Vicarious.
Default Good compression?
I took a cold compression test on my rebuilt engine (stock bottom end) and came out with 125-140 psi on average. (with all of the plugs out)
These new piston rings only have about 75 miles on them, but they went through alot of abuse from unburned fuel & idling with oversized injectors.
So is this good pressure for a cold check on a new engine? I can't fire it up yet to check it warm.
Old Oct 7, 2011 | 08:08 PM
Vicarious.'s Avatar
Vicarious.
ttt
Old Oct 7, 2011 | 10:02 PM
DBLTRGR's Avatar
DBLTRGR
Throttle open or closed?
Old Oct 8, 2011 | 01:45 AM
Vicarious.'s Avatar
Vicarious.
At the time I didn't know that I was supposed to use the gas pedal...so throttle closed.
Old Oct 8, 2011 | 11:09 AM
DBLTRGR's Avatar
DBLTRGR
Those readings will be higher with the throttle held open.
To Good compression?
