Those Running Pilot Sports...Have ?
Old 05-03-2002, 04:04 PM
C54FUN
C54FUN's Avatar
St. Jude Donor '03-'05-'06-'08-'10
Default Re: Those Running Pilot Sports...Have ? (Buckmaster)
I run 'em 32lbs. all around.
Joe
Old 05-03-2002, 05:04 PM
RoliO
RoliO's Avatar
Buckmaster,
I am running the same set up as you are, except with FM5's :D and am running at 28psi on all 4. I just happened to check it the other day. Those settings are how they came from Xtreme as they mounted, and balanced the wheels/tires for me. :) Is this too low of a pressure to run? :cheers:
[Modified by RoliO, 3:04 PM 5/3/2002]
Old 05-03-2002, 06:41 PM
COOL Z06
COOL Z06's Avatar
I running 30psi cold all around.
Same size as you in the rear with 275/40-17's in the front.
Old 05-03-2002, 06:51 PM
OliverM5
OliverM5's Avatar
Run 31-32 in front and 30 in the back COLD. THat will give you the best balance between handling and straight-line traction.
Old 05-04-2002, 12:03 AM
jschindler
jschindler's Avatar
Default Re: Those Running Pilot Sports...Have ? (COOL COUPE)
Old 05-04-2002, 01:22 AM
Flashman
Flashman's Avatar
35PSI all around...
265 35 zr18's up front
295 35 zr18's in back
It's a firmer ride and well within spec.
Old 05-04-2002, 01:30 AM
Viprklr
Viprklr's Avatar
Default Re: Those Running Pilot Sports...Have ? (Flashman)
30psi cold on all four. I have the same sizes as you. :D
Old 05-04-2002, 02:24 AM
BlackSun!
BlackSun!'s Avatar
Default Re: Those Running Pilot Sports...Have ? (Viprklr)
30 all around...
Old 05-04-2002, 03:23 AM
jetskifast
jetskifast's Avatar
Same size tires, running 32 psi on all four corners.
Old 05-04-2002, 03:43 AM
dexter
dexter's Avatar
Hey Buckmaster :seeya
Are you going to carry any kind of patch kit now or are you going to rely on a Triple A card and a cell phone?
Old 05-04-2002, 02:02 PM
L.A.P.D.
Supporting Vendor
L.A.P.D.'s Avatar
St. Jude Donor '03-'04-'05-'06
Buckmaster,
I have the same tires sizes. The correct amount of psi to run is:
Front: 30 psi cold
Rear: 31 psi cold.
Trust me on this one.
Hope this helps.
Shawn
Old 05-04-2002, 09:50 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
34/32 rear
Old 05-04-2002, 10:20 PM
see5
see5's Avatar
Yup, 275 front and 32 cold which goes up 3 or 4# warm.
Old 05-05-2002, 12:55 AM
MelloYellow
MelloYellow's Avatar
I prefer my Tire Pressure much lower than most.
26-27psi cold.
I find my car/suspension/tires get WAYYY too bouncy at high speed, 130-150 if the Hot psi reaches 30+ psi. Dangerously bouncy. Lower pressure seems to help. I like to see around 28-29psi Hot.
Also, the lower pressure helps launching/traction from a dead stop. Less wheel hop.
Old 05-05-2002, 04:09 AM
davidmax
davidmax's Avatar
Default Re: Those Running Pilot Sports...Have ? (MelloYellow)
28-32 all around ,on a long hi-way trip 34 all around if you live in AZ.32-34 for long trips at hi speeds the Pilot Sport can handle alot of abuse,but its always good to fill em up on the hi-way if your going triple digit #'s for extended periods so you dont Heaven forbid wind up like the explorer problem all due to under inflation 26 on all4 for ride comfort,SUV's are truck platforms and arent made to drive like an N-Benz so pre load them and get some good bite and no accidents.Yours Truly Dave s.PS.
28 psi around town is ok even with an occasional 150 mph boost.Dave.
Old 05-05-2002, 02:15 PM
L.A.P.D.
Supporting Vendor
L.A.P.D.'s Avatar
Buckmaster,
Don't drag the car. Mostly autocross is what I really abuse the tires under.
When autocrossing, I usually put a couple more lbs. psi in the front tires and leave the rears at 31 cold.
Under severe autocrossing conditions, the tires may rise to almost 39 lbs. in each tire.
For the street, run 30 psi cold in the fronts and 31 psi cold in the rears.
You will be happy with the way the car rides and handles with that amount of pressure in the tires.
Shawn
Old 05-05-2002, 03:03 PM
Allgonoshow
Allgonoshow's Avatar
Quick ? guys. Will the 295/35/18 fit on a stock C5 rim?
To Those Running Pilot Sports...Have ?
Quick Reply: Those Running Pilot Sports...Have ?
