C5 Torque Tube Snap Ring
Old Oct 10, 2011 | 04:46 PM
Perkyboy's Avatar
Perkyboy
Default C5 Torque Tube Snap Ring
Trying to get a part # for the Large Snap Ring that holds the rear drive shaft bearing in the rear of torque tube on a 04 C5 with 6spd ? or if anyone knows where one can be Purchased, Any info would be Appreciated ?
Thanks Perk
Old Oct 11, 2011 | 12:37 AM
Perkyboy's Avatar
Perkyboy
Cmon somebody must know a part # ??????
Perk
Old Oct 11, 2011 | 11:10 AM
voda1's Avatar
voda1
#88894018 - 71mm dia
Old Oct 11, 2011 | 11:13 AM
Perkyboy's Avatar
Perkyboy
Is that a GM part # ??
Old Oct 11, 2011 | 12:17 PM
cdkcorvette7's Avatar
cdkcorvette7
It appears to be. If you put it into the part number search on gmpartshouse.com it comes up...
Old Oct 11, 2011 | 01:37 PM
Perkyboy's Avatar
Perkyboy
I think I might of not explained properly, What I need is the snap ring or collar that holds the whole rear bearing housing into the Torque Tube, My whole shaft is assembled with rear bearing installed but I am trying to find out what holds it in torque tube, The bearing housing itself has 3- 10mm bolts in it that enter from the rear & I cannot find anywhere a picture showing where the 3 bolts go, It seems like I am missing a collar that would locate the rear bearing housing in torque tube, The 3 bolts have to go into something but I cannot find anything showing where, I did not disassemble so I do not know what I am missing as this is the way I got it ??
Perk
Old Oct 11, 2011 | 01:38 PM
Perkyboy's Avatar
Perkyboy
I have a pic but it say's I cannot post attachments ??
Old Oct 11, 2011 | 01:39 PM
cdkcorvette7
Open a free photobucket.com account then upload the pic and copy the image code into your post...
Old Oct 11, 2011 | 03:06 PM
Perkyboy's Avatar
Perkyboy
Here is the Pic, Thanks !!
Old Oct 15, 2011 | 04:42 PM
JOEY CARTEE's Avatar
JOEY CARTEE
The bolts are used as jack boltsto remove the shaft assembly. The snap ring is that holds the assembly in. Most will t app easliy rite out with a small piston hammer. Do not beat on the input shaft. Use a peice of wood.
Old Oct 15, 2011 | 08:22 PM
Perkyboy's Avatar
Perkyboy
Thank you much, I I knew there had to be somebody out there that could tell me, They do not say anything about the bolts in the Helms shop manuals I just bought, I think I located a snap ring, I would like to buy a new one if somebody could tell me a part # on the Large snap ring that holds the whole bearing carrier into torque tube ?
Perk
To C5 Torque Tube Snap Ring
