Lowering question
Old Oct 10, 2011 | 08:22 PM
rnelson11's Avatar
rnelson11
Default Lowering question
If I lower my 2004 using the stock bolts what are the repercussions of not doing a 4 wheel alignment?
Old Oct 11, 2011 | 03:34 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Poor handling charateristics, excess tire wear.
Old Oct 11, 2011 | 10:04 AM
cdkcorvette7's Avatar
cdkcorvette7
Unless you're really careful and really lucky it'll drive like $hit. Get an alignment if you're going to lower it. In the end it'll be cheaper because your tires will last longer.
Old Oct 11, 2011 | 10:46 AM
4SFED Z's Avatar
4SFED Z
An alignment is 40 bucks. Some cars, alignment is way off, others not so much. Problem is that many owners just bottom out the bolts as far as they go. If you look before hand, you will see that some bolts will have more threads exposed than others.
To avoid the next question, you measure at the frame rails
Old Oct 11, 2011 | 12:45 PM
hotwheels57's Avatar
hotwheels57
Good luck finding an alignment for $40...a four wheel alignment will cost more in the neighborhood of $60-80 depending on the shop.
Either way, that's much cheaper than new tires for $300+ each...
Old Oct 11, 2011 | 04:42 PM
rnelson11's Avatar
rnelson11
I will deffinately be getting an alignment after I lower it.
Old Oct 12, 2011 | 03:48 PM
4SFED Z's Avatar
4SFED Z
Really? There is a place here in houston that does it for $40. Thanks for your input.
To Lowering question
