Instrument Cluster Bulbs
Old Oct 12, 2011 | 03:26 PM
Kemeyes's Avatar
Kemeyes
2nd Gear
Default Instrument Cluster Bulbs
How do you replace the instrument cluster light bulbs on a C5 corvette?
Old Oct 12, 2011 | 03:45 PM
cdkcorvette7's Avatar
cdkcorvette7
Enormous PITA: http://www.spdkilz.com/techtipleddic.html
Old Oct 12, 2011 | 04:00 PM
Kemeyes's Avatar
Kemeyes
2nd Gear
Originally Posted by cdkcorvette7
I just need to change a loose bulb for one of the push buttos on the right side. Do I still need to remove the whole cluster?
Old Oct 12, 2011 | 04:16 PM
cdkcorvette7
Yes. Unless I'm mistaken (the info should be in the link I gave you) that switch panel is bolted into the back of the cluster with two torx bolts. You'll need to remove the cluster to gain access to the back to replace the bulbs. My understanding is that OEM bulbs for that panel are difficult to find, the link I posted tells you how to replace it with LED's. Alternatively, a new switch panel is around $40. You might consider just replacing it.
To Instrument Cluster Bulbs
