Spark Plugs
Old Oct 11, 2011 | 05:26 PM
buckster's Avatar
buckster
Default Spark Plugs
What are the best and longest lasting plugs to use for a weekend cruiser ? I was watching speedchannel and they were working on a C 5 and they were recommending some new champion plugs. How long should plugs last for a summer driven c 5 Z 06 with headers ( if that even makes a difference, don't know ? )
Old Oct 11, 2011 | 05:27 PM
baxsom's Avatar
baxsom
stock.
Old Oct 11, 2011 | 06:59 PM
bighank's Avatar
bighank
Default Iridium
Replacement for older platinium
Old Oct 11, 2011 | 09:50 PM
ZeeOSix's Avatar
ZeeOSix
Yep ... iridium plugs will last the longest. Also note that the spark plug gap was changed from 0.060" to 0.040" awhile back - ACDelco has a service bulletin indicating, so don't try to re-gap iridium or platinum plugs for the LS1/LS6.
Old Oct 12, 2011 | 08:15 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Yep, thats me...........
Old Oct 12, 2011 | 09:22 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
NGK iridium or ac delco 41-110
Old Oct 12, 2011 | 10:29 AM
Gideon's_Test's Avatar
Gideon's_Test
Best performance: Copper plug
Longest lasting: AC Delco Iridium or NGK Iridium
Old Oct 12, 2011 | 12:54 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
All the "new material "plugs of late are great for longivity--But there is no HP gains if you have the correct heat range---
The main thing to remember---Even though the plugs can last 100K miles---you still need to remove them at least every 40K miles or so OR you will never get them out!! The plugs become sorts welded in with rust-carbon and sometimes even break off if you don't take them out once in awile--opening up a host of new problems for you--Also using just a tpouch of anti-sieze when installing new ones will prevent them form getting "glued" to your heads !!!
Old Oct 12, 2011 | 02:32 PM
cdkcorvette7's Avatar
cdkcorvette7
Replace your plug wires too. If you still have your stock wires chances are you will break every single one of them when you go to swap plugs...
To Spark Plugs
