nitrogen in tires
Very true BUT all passenger car tires will wear out long before oxidation is an issue. Unless you store them for a very long time which answers the question the OP had. Personally, for long term storage, I would use nitrogen. Normal everyday driving - waste of money.
Very unlikely for a passenger car tire. For a truck tire, 100% true because they are retreaded. Carcasse life is important.
>>> “the oxidation of the steel-belt rubber" and cable and carasse wire.
This is the primary reason it is used in truck tires. Truck tires not only have steel belts, they have steel carcasse plies. Oxygen will deteriorate the carcasse very quickly making the retread life of a truck tire much shorter. Nitrogen makes sense for truck or aircraft tires.
Marketing and Sales at its best.
Most people will check their tires at least once per year. So this difference is insignificant for normal road car use.
Racing tires, main reason is to remove moisture which has an extreme influence on pressure variation. Aircraft tire because there is lots of steel in the carcasse and they run at very high pressure - typically ~200psi. High pressure = more oxygen migration = more oxidation = tire failure so the solution is to remove the oxygen. Same holds true for heavy truck tires.
Absolutely true BUT the tire tread will wear out long before you have a belt separation unless the tire is severely abused - i.e. very low pressure and very high load for long periods of time in Arizona. Unless, you store the tires inflated for a very long time. Back to the OP question... long term storage I would use nitrogen. Normal passenger car usage it is a waste of money.
See above. Racing primarily to reduce moisture content.
This is where I have the biggest problem. General comments like "makes a big difference" I believe is totally false. It does make a difference but I believe the difference is insignificant. You'll save much more money keeping a good air filter on your engine. Although the 0.3% general claim is true. Varies tire to tire.
You took all that time, and responded to a cut/paste from the internet.
Nothing wrong with a debate on something I haven't seen mentioned very often and providing useful info for people to make a decision on. I made mine and know it will solve my corrosion issues and the rest of the benefits are just gravy.,
And it only costs $19.95 and if you call now, they'll through in a free tire gauge (valued at $40), and if you act now, we'll also through in another batch of nitrogen for another 4 tires Free! Yes you heard right! That's an $80.00 VALUE for $19.95!!!
People are gullible...it's their nature!
Perhaps the average Joe would be wise to install a water separator or dryer on the compressor in their garage.
Personally I use a bicycle pump, totally portable and exercise to boot!
Stick with AIR which is 80% nitrogen.
Good one!
And that right there is why your tires stopped leaking, nothing to do with the nitrogen fill. Nitrogen is a 'good idea' for the lack of o2 and slightly less pressure change with temps but don't make it into magic snake oil that somehow stops bead leaks.
