Shift light?
Old Oct 14, 2011 | 12:49 PM
princerobert1's Avatar
princerobert1
Default Shift light?
just wondering do you need a tach adapter to run a shift light on a 2002 corvette zo6
Old Oct 14, 2011 | 02:02 PM
Gideon's_Test's Avatar
Gideon's_Test
Not sure how to answer your question, but my tuner turned my 1st to 4th gear skip shift light into a shift light...Works pretty well, I can just see it in my peripheral vision when I need to shift.
Old Oct 14, 2011 | 02:08 PM
princerobert1
really how did he do that do you know
Old Oct 14, 2011 | 02:23 PM
Gideon's_Test
Not sure what software he used, but it was one of the commercially available ones. Sorry not to be of more help...
Old Oct 14, 2011 | 04:15 PM
princerobert1
its cool thanks anyway bro and btw your car looks awsome
Old Oct 14, 2011 | 04:19 PM
JD White's Avatar
JD White
I can't speak for other software but I use HP Tuners and it's just a basic function they've built into the software to use the skip-shift light as a shift light.
Works well and has several adjustable parameters.
Certainly not worth the cost of the software just for a shift light but I'm sure you could find someone nearby or a shop that would do it for you for pretty cheap or free.
-Jon
Old Oct 14, 2011 | 04:23 PM
princerobert1
ok sweet maybe ill see if they can do it when my car go's on the dyno but the question still remains do i need a tach adapter lol
Old Oct 14, 2011 | 04:28 PM
JD White's Avatar
JD White
If you're using the software, no.
Even if you wanted to use an external light elsewhere you could tap the leads/circuit of the skip-shift light to connect an external light.
-Jon
Old Oct 14, 2011 | 04:31 PM
princerobert1
thats a good idea thanks
Old Oct 14, 2011 | 04:33 PM
boofoo's Avatar
boofoo
3rd Gear
I think that depends on the shiftlight you want to use.
I personally like the Raptor shiftlights they do not require tach adapter.
Old Oct 14, 2011 | 04:45 PM
bumble-z's Avatar
bumble-z
I agree & it's easy to hook up.
Old Oct 14, 2011 | 05:18 PM
had2have-it's Avatar
had2have-it
The Raptor is a real nice piece, used them on a few motorcycles. They make them for cars to; a quality, versatile self contained unit that's programable and really works.
Old Oct 14, 2011 | 06:59 PM
PRE-Z06's Avatar
PRE-Z06
Here's an example of it in action...
http://www.youtube.com/user/vegaman7...13/tlvrwzLX_sc
Old Oct 14, 2011 | 07:23 PM
princerobert1
yea the raptor shift light are cool and all but arnt they like $100 i dont think ima pay $100 dollars for a fancy blinking light
Old Oct 14, 2011 | 08:23 PM
had2have-it
For the price of 2 1/2 tanks of gas you could have a real shift light that you could depend on and help make you a better driver
Old Oct 16, 2011 | 07:42 PM
JD White's Avatar
JD White
You can fill your tank for $40! Looks like I'm moving south.
Old Oct 16, 2011 | 08:06 PM
Tourmgr1's Avatar
Tourmgr1
The search function is your friend and with it posts going back to 2003 can be found.
This is the best if you want to hard wire a Raptor into your car...and it still has pics.
Many thanks to Flyin'Brian.
http://forums.corvetteforum.com/c5-t...-big-pics.html
Good luck.
To Shift light?
