Adjustable Swaybar End Links Question
Old Oct 19, 2011 | 08:17 PM
C5Natie's Avatar
C5Natie
Default Adjustable Swaybar End Links Question
Hey guys, are adjustable endlinks worth it on a street car, spirited driving and occasional hpde? I have c6z sways and was wondering if this would be a good upgrade and wether its worth it. Also what are the advantages over the oem aluminum ones? Thanks.
Old Oct 19, 2011 | 08:32 PM
WICKEDFRC's Avatar
WICKEDFRC
Just my opinion and it is not an expert one at that.....
I think they were not worth the money nor the time to "dial in" the adjustments.
I had adjustables and I just ordered the C6 metal end links to replace them. Whether my decision is good or bad, who knows. But one thing is for sure, I don't have to worry about adjusting crap anymore.
Old Oct 19, 2011 | 10:21 PM
C5Natie's Avatar
C5Natie
Thanks for the input. I wondering too if it would be a PITA to be adjusting them.
Old Oct 19, 2011 | 11:20 PM
mountainbiker2's Avatar
mountainbiker2
The advantage to having adjustable endlinks is for making sure your sway bar has no preload on it. I wouldn't worry about it. You would have to setup the car with the same amount of weight for it to really work properly.
Steve A.
Old Oct 19, 2011 | 11:56 PM
C5Natie's Avatar
C5Natie
Hey thanks guys. I guess i will just stick with my c6z metal ones.
Old Oct 20, 2011 | 12:00 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
it makes since if you're running coilovers and have the car corner balanced. you do this without the swaybars connected so there is no pre-load. The last thing you do is connect the SB with it adjusted either netural or with a pre-load. The adjustment allows you to set this. hope this makes since
Old Oct 20, 2011 | 08:32 AM
mountainbiker2
Originally Posted by printmanjackson
connect the SB with it adjusted either netural or with a pre-load. The adjustment allows you to set this.:
You might want pre-load, only if you're circle racing.
To Adjustable Swaybar End Links Question
