service ABS, Traction control & Active Hand
Old Oct 20, 2011 | 09:13 AM
rebel26's Avatar
rebel26
4th Gear
Default service ABS, Traction control & Active Hand
Help My Service ABS, service active handling & service traction control warnings come on, usually around 40 MPH.
My mechanic thinks it the right front wheel sensor & it is expensive.
What if I do nothing?
Car is a 2001 with 30000 miles.
Some door codes &
28-TCS C1233H
Old Oct 20, 2011 | 09:22 AM
dougbfresh's Avatar
dougbfresh
Pull your codes. If you do not know how to do that-try Advanced Search-100's of posts on it.
Old Oct 20, 2011 | 02:52 PM
BigGun's Avatar
BigGun
Some door codes &
28-TCS C1233H
While the code indicates a faulty sensor it is almost always due to the wiring or connector. Parts are not that expensive (unless it turns out to be the ebcm) it just requires a little troubleshooting to locate the problem. Search the code, lots of information on the forum for dealing with this.
Old Oct 20, 2011 | 03:27 PM
lucky131969's Avatar
lucky131969
Originally Posted by BigGun
While the code indicates a faulty sensor ....
C1233 does not indicate a faulty sensor. Specifically, it is a open or shorted RF wheel speed circuit issue.
Old Oct 20, 2011 | 04:34 PM
johnson-rod's Avatar
johnson-rod
Try switching the sensor wires from right to left side. See if error follows it.
Old Oct 21, 2011 | 07:44 PM
rebel26's Avatar
rebel26
4th Gear
good idea.
Old Oct 22, 2011 | 07:15 PM
halp's Avatar
halp
I had a similar situation the other day at about 70 MPH. Messages went away after the engine was re-started. Pulled codes and got
28-TCS C1214H (Sol valve relay contact or coil ckt open).
Have driven the car since and the message has not returned.
2002 Z06
To service ABS, Traction control & Active Hand
