Stupid Metal End Links!
Old Oct 21, 2011 | 10:09 AM
REZ1's Avatar
REZ1
did mine last month......in about an hour....used a lift and for the front removed tires and moved the assembly..(rotor) for easy access.....one wrench on back and on on front..
no problem
Old Oct 21, 2011 | 10:55 AM
cdkcorvette7's Avatar
cdkcorvette7
Are you sure you got the right bolts? Have you tried your old ones?
Old Oct 21, 2011 | 01:20 PM
rtpassini's Avatar
rtpassini
St. Jude Donor '11-'12
yup. everything is the same.
Old Oct 21, 2011 | 05:32 PM
lionelhutz's Avatar
lionelhutz
They look like these?
http://www.mamotorworks.com/corvette...-190-8359.html
Did they come with new nuts? The nuts should go on easy until the stud is almost right through and then they require wrenching the rest of the way. They still shouldn't be too hard to turn on though.
I have a set of C6 take-offs that look almost the same as the ones in that pic but they have a 8mm hex instead of the Torx hole. I just checked and the nuts off the old plastic end links look exactly the same and will fit these no problem.
If you have some aftermarket link then maybe you're trying to force the old nut onto the new link and they have a SAE thread and not a metric thread.
Peter
Old Oct 21, 2011 | 06:14 PM
rtpassini's Avatar
rtpassini
No new nuts. But they look like that. the nuts go on with issue until the bolt gets to that back of the nut.
Old Oct 22, 2011 | 09:14 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
What is the GM part number of your metal links?
Old Nov 4, 2011 | 10:17 PM
Sayfoo's Avatar
Sayfoo
Originally Posted by Cross
I used the Moog's and didn't have an issue. I did find the ones on the front endlink hard to tighten on the car but remove the sway bar and it is easy.
Do these have grease fittings?
What is your overall impression to these?
Old Nov 4, 2011 | 10:48 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Mark original position of sway bars and loosen the sway bar mounts quite a bit. Then install and lightly snug up the end links. Make sure the end links are on the same thread count on each side and front and back of the links, very important. Then tighten the sway bar mounts back up to spec. Make sure the wheels are square, (Front). Then snug up the links!
Helps to have Leprkon and C6 Batmobile show you how to do it! Now I know! So do you!
Good luck, you can do it, patience!
Great mod and you will FEEL the Diff!
Old Nov 5, 2011 | 12:10 AM
Dale002's Avatar
Dale002
If you having problem with just one,maybe the nut is crossed threaded. I've chaged them in a couple of C5 using GM and the stud is threaded all the way down. There is no way you couldn't tighten them down due to thead issues. Post a picture!
Old Nov 5, 2011 | 02:09 PM
thetaxman's Avatar
thetaxman
totally not necessary
Old Nov 6, 2011 | 08:26 AM
skeeters65's Avatar
skeeters65
I just installed new metal end links yesterday along with C6Z06 shocks.
What a huge improvement!!!
4 end links and 4 shocks took me about 3 hours..
Old Nov 6, 2011 | 08:41 AM
SG Lou's Avatar
SG Lou
No grease fitting on these.
I also just installed the newer updated version ( GM LINK, Genuine GM
part# 20822934) with the 10 mm hex ends as opposed to the recessed torx fitting and they are fine. Although they did get a little snug the closer you got to bottoming out the nut but they still went on with no problem.
Old Nov 6, 2011 | 12:32 PM
  #33
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
the studs do look very long---You must use 2 wrenches as said earlier--OR use a small wrench on the hex end of the stud-- Best is to take the sway bar COMPLETELY OFF--
The threads go all the way to the beginning of the link shoulder--so they shouldn't botton out when tightening--If the stud hex end is hitting something and there is a clearance issue that's something else--remedy would be to cut-off the end about 1/2-3/4"
Old Nov 6, 2011 | 02:36 PM
  #34
garllo's Avatar
garllo
I replaced my shocks and sway bar links last month. I used links from Raybestos. N o problems at all!
Old Nov 7, 2011 | 09:51 AM
  #35
mitchb's Avatar
mitchb
I just ordered some replacement links from GM for the rear on my 99. I thought this would be easy but after reading what you had to say maybe I will take it to a dealer with a corvette mechanic. I just went through column lock hell with this car and don't want any more surprises. Thanks for sharing.
Old Nov 7, 2011 | 09:54 AM
  #36
mitchb's Avatar
mitchb
Just curious, but how much torque is required when tightening these?
Old Nov 7, 2011 | 01:05 PM
  #37
Dale002's Avatar
Dale002
it's really easy to do,I never heard of these issue unless it was crossed threaded on installation and thy were forced on.
To Stupid Metal End Links!
Old Nov 7, 2011 | 01:15 PM
  #38
SoDiezl350's Avatar
SoDiezl350
55 ft-lbs
Old Nov 7, 2011 | 09:08 PM
  #39
lionelhutz's Avatar
lionelhutz
I didn't have any trouble installing mine on the front. The link will just slip in with the car on jack stands and the suspension hanging. I just held the link side of the stud with an 18mm wrench and hit the nuts with an impact but you could use a rachet as easily.
Peter
Old Nov 16, 2011 | 07:12 PM
  #40
flynhi's Avatar
flynhi
My Vette Tech says 50 ft lbs.
