Check Bad Lifter In Car???
It's surprising the range from lobe to lobe, subjective being I was using Calipers. They are good Calipers so I'm comfortable with go...no go numbers.
Vettenuts have you ever measured the Base Circle lobe to lobe?
You combine an error on the Base Circle with how a valve is seated? You wonder how any of it can work
Then the push rod length & rocker arm & how the head was milled were the rocker shaft seats...OMG
When I installed the rocker arms, I made note of how many turns it took on each one to go from zero lash to 22 ft-lbs (avg was 1-1/4 turns). Converting that to a lifter pre-load, the total range variance from least to greatest pre-load distance was only 0.012". Tells me all the valve stem heights and cam lobes/base circles were pretty darn consistent.
My valve train is probably as quiet as they get in the LS6. With the hood closed, you can't really hear much at all. Have to put your ears down a foot above the rocker covers to hear some slight sewing machine noise. My lifters are pretty much pre-loaded to the mid range of their travel (~0.060" for my stock LS6 lifters) ... just like they came from the factory.
Looking forward to your input!
When I installed the new rods the valvetrain got quieter overall, but there were new sounds. After a couple of days I started realising they were not normal sounds and were beyond the typical big cam LS1 sewing machine.
The lifter with the most pre-load will be IN #1 at 0.138" which is getting pretty close to the 0.166" limit of the lifter's travel - only 0.030" to spare. Can't recall if having too much pre-load is supposed to quiet down the valve train or make it more noisy ... but 0.030" headroom is cutting it close IMO.
Also, did you verify the travel range of those LS7 lifters? Who knows how accurate that data sheet is that shows the travel dimensions of the lifters.
It does sound like the cam has inconsistent lobe & base circle dimensions.
I think the best you could do here is shoot for a pushrod length that gives you the average minimum + or - away from the mid-point pre-load of 0.082".
Either that, or you could really go wild and custom order every pushrod to be specific for each lifter. Manton pushrod would do that for you - they make pushrods to order. You would have to have good confidence in your measurements to go that route and a way to measure each pushrod to match them up to their specific locations during installation. Could be a lot of hassle involved.
Your preload calculations agree with mine. I agree, with the 7.425" rods there were several lifters operating with far too little headroom.
Something is not adding up, maybe the cam is out as you say.
Good to hear about the consistent numbers. Mine are varying over 3X that much.
I may remove the rocker stands and measure the individual trunion mounts just to see what kind of variation lives there, if any. That's the only other thing I can think of beyone the base circles being out of whack on the camshaft.
I can't see the rocker stand bosses being machined different from each other since they likely all get machined by the same machine set to one height, and this would happen after the bottom surface of the head was finished. I doubt there's many issues with the head itself.
I would accept that maybe the cam bearings could have been bored off center, but that would show up as all measurements for one head being higher than the other and that's not the case here.
Everything seems to point to the cam, and d@mmit that's the one thing I can't measure since it's in the block already. I wonder how LPE would feel about getting one of these cams off the shelf and measuring all of the base circles for me... right.
A little wiser each time.
My current push rods are Manton 11/32 thick wall. We had a good conversation on the phone verifying what I had measured. Interesting stuff. They are very approachable people.
I've been chasing a power issue, thats brought on my little chase the tail syndrome.
To clarify, there are a couple of different ways to measure pushrods. I've learned a lot about them since I've done my mini valve train upgrade on my '02 Zee. See this thread - particularly post #13 and #24 and the attachments in those posts.
http://ls1tech.com/forums/generation...ness-spec.html
The OEM pushrod with a 5/16" dia ball end will have a "gauge length" of 7.385" and a "flat-to-flat" length of 7.400". This is where the trickiness comes into understanding pushrods. The basic key is to know how the length has been defined.
BTW, the custom pushrods I had built by Manton were only $10 each.
And those LS7 lifters have a relatively huge travel range - 0.166" compared to my OEM LS6 lifters which only have 0.126" travel. The setup is even more critical on the LS6 lifers since there is 25% less travel range to play with.
At the end of the day, as long as each pushrod is keeping its respective lifter happy that's all that matters. In my case there's so much variation I'm wondering if the cam lobes are even ground properly and I'm getting the intended valve lift? What about the delicate closing ramp geometry? Maybe this is why I still have some valves that are louder than others?
These are questions I wasn't planning to ask...
As mentioned previously there are builders that are fussy doing this, I would not hesitate to do this. Maybe one day if I can get my other haunting issue's squared away I would go back & do it just for the education & who knows, a quieter valve train. I would even do a before & after dyno.
I really hope this information helps someone out!
Custom Mantons for $10 each? That sounds too good to pass up! When I go to roller rockers I will be sure to call them. Their product looks far superior to the Comps I'm using now, and not much more money.
The OEM LS1/LS6 pushrods are 7.400" between the flats from tip-to-tip, which corresponds to a "gauge" length of 7.385" as I detailed in my thread on LS1Tech.com.
I don't know for sure ... but I'm assuming the (Comp Cams?) adjustable pushrod you used is designed to measure the required pushrod "gauge" length? If not, and it gives you overall length, then there could be about a 0.015" difference going on between what you measure and what you use. You have to be careful to know which length measurement system is being used.
What's weird about Comp Cams is they list a "7.400" inch long pushrod as the LS1/LS6 OEM. Well, if Comp Cams defines their pushrod length by gauge length, then are they 7.385 gauge length, or 7.400 gauge length ... which would actually be about 0.015" longer than the OEM pushrods. See what I'm getting at?
). This would suggest the checker is providing gauge length, which is what I would expect since it should corelate to Comp's products.That said, it is a pretty crude measurement and 0.025" error is possible. I went out to the garage armed with my nice Mitutoyo caliper determined to get an accurate measurement only to find once I got there that the caliper only measures to 6".
The confusion with measurement techniques seems to stem from two sources:
1. Manton uses an overall length spec (which, in my opinion, doesn't make sense since the overall length can vary depending on the size of the oil hole in the end of the ball... bigger hole, longer rod!)
2. Comp specifies 7.400" pushrods as stock replacements without a footnote detailing that they are actually 0.015" longer. Dumb, but probably avoids scaring people off who don't know their lifters have a "range" to work in.
). This would suggest the checker is providing gauge length, which is what I would expect since it should corelate to Comp's products.1. Manton uses an overall length spec (which, in my opinion, doesn't make sense since the overall length can vary depending on the size of the oil hole in the end of the ball... bigger hole, longer rod!)
Less oil into the heads at high RPM sounds like a good idea. GM has had oil starvation issues with cars on the track; long, high-G turns don't allow oil to flow back down into the crank case from the cylinder head, so putting less oil up htere in the first place could help that situation. Pretty simple.
Though if it was that simple, and less oil was required in the heads, it begs the question "Why didn't GM just do that in the first place?". Maybe the extra oil is needed at high RPM to keep the valve springs cool or something? Quite often things like this are not understood before a change is made.
