Interesting... so the Mantons actually have a flat machined into the base of the ball end and then have a hole drilled that is smaller? I guess this is necessary if he is supplying them based on overall length instead of gauge length.
Yes, there is a flat at the end of the Manson (on left) ... you can see it in this photo. I measured it, and it was within a few thousands to the flat in the OEM pushrod (which is on the right). Manton also claims that with the smaller oiling hole, there is more material in the ball end where it mates with the rocker arm and lifter, so there is less stress in the material in that area.
Check to see that you don't have a lose spark plug --- that can cause a ticking noise too. Also, get a set of rocker stoppers which will allow you to run the engine with the valve covers off and oil won't squirt all over the place --- cheap but very handy to have on hand.
"Rocker Stoppers" --- probably cost $5 bucks
Anymore news on this, I'm going through the same thing and going nuts trying to figure it out. Just put in new ls7 lifters, one I can push down by hand but it does come back up on own immediately.
2000 coupe
Ls6 243 heads not touched
Mls head gaskets
Comp cam 224/224 lsa116+2 567/567
Upgraded truniuns
Ls6 intake manifold
Bosh 30 lb injectors
Melon high volume oil pump pressure at idle 40 warm 50 cold
New water pump , temp 180
918 bee hive comp springs
New exhaust valves and guides stock z06
Ls7 lifters and trays
Arp studs
7.400 comp push rods
Tuned by chuck cow
