C5 wheel clearances
Old Oct 24, 2011 | 07:39 PM
Spartan 45's Avatar
Spartan 45
Default C5 wheel clearances
Will 19x11 C6 / Z06 REPRO'S FIT THE REAR OF A C5 ?
18X9.5 ON THE FRONTS?
Old Oct 24, 2011 | 08:23 PM
Jnape's Avatar
Jnape
NO.
I run oem C6Z wheels on my C5. I did a 2" mini tub as well as fender flares. With the 345/30/19 tires, thry tuck in great and NO tire sticking out at all....
Old Oct 24, 2011 | 09:10 PM
Spartan 45's Avatar
Spartan 45
Default wheels
Thanks Jnape.
Old Oct 24, 2011 | 09:41 PM
cvette98pacecar's Avatar
cvette98pacecar
Originally Posted by Jnape
NO.
I could have swore the C6 Z06 rim is 19X12, Well at least those are the 360 wheels I have on my Z06, Thanks for saving me about an hour of work I was going to see if my Z06 rims would clear my pacecar wheel wells. Have a great opportunity to buy a set of New GS rims and tires for less than a grand.
Old Oct 24, 2011 | 10:16 PM
Jnape's Avatar
Jnape
Originally Posted by cvette98pacecar;1579045801[B
]I could have swore the C6 Z06 rim is 19X12[/B], Well at least those are the 360 wheels I have on my Z06, Thanks for saving me about an hour of work I was going to see if my Z06 rims would clear my pacecar wheel wells. Have a great opportunity to buy a set of New GS rims and tires for less than a grand.
They are. Aftermarket wheels that say they are C6Z might not be the same width or offset. You can't beat the price of oem sold here used. I got all 4 with 2k miles on them for $1000. At $250 a pop they are a good deal.
The weight savings alone Vs. aftermarket mean a ton. You can really feel a difference in acceleration with the extra weight of what I run.
Old Oct 25, 2011 | 10:51 AM
rebelheart's Avatar
rebelheart
I went from light weight factory magnesiums to C6 repos and my ET did not change one bit! I have C6 repos in C5 offsets 11 in and only had to add a 1/4 inch spacer to the rear because of light scuffing on the inner fender shield,
Old Oct 25, 2011 | 05:55 PM
Spartan 45's Avatar
Spartan 45
Default Rims /tires
today I took the rims and tires up to a shop in Pasadena, MD. They were mounted, balanced and they fit the stock 2002 C5 without rubbing. Sold the rims tires and the stainless steel exhaust.
Old Oct 26, 2011 | 09:25 PM
davisce's Avatar
davisce
Originally Posted by Spartan 45
Will 19x11 C6 / Z06 REPRO'S FIT THE REAR OF A C5 ? 18X9.5 ON THE FRONTS?
Yes, I'm running 18x9.5 C6 Z06 after markets wheels on the front of my 1999 C5 with 265/35x18" tires and 19x11's on the rear with 305/30x19" tires on the rear. No rubbing. I ordered the wheels from "West Cost Corvette".
Old Oct 27, 2011 | 09:51 AM
rebelheart's Avatar
rebelheart
Those are same size tires I am running(PS2's).Maybe I drive a bit more spirited as the rears lightly rubbed on the inside edge.
To C5 wheel clearances
