Loading Car for Tire Alignment?
Probably takes quite a few tire alignments till it's paid off though?I'm actually looking to start a shop myself... I've been writing these manuals and making a couple bucks here and there to supplement my no-existent income. I also parted out a car on ebay (looking for more cars now). Been doing everything humanly possible to make a living since getting laid off
I am enjoying the car work though and it seems to actually net some positive cash flow
It's just chump change right now though (working out of my two stall garage) but I think with a shop I could change that all.You guys are welcome to check out my latest rough cuts for my tire manual. I've just got one of the sensors rebuilt so far. There will be a bunch more tutorial videos on there related to tire maintenance, care, and proper jacking procedures including how to make heavy duty jack pucks when I'm done
2001-2005 Sensor Rebuild Intro
Sensor Disassembly
Sensor Assembly
Thanks again for all the advices...
With respect to the alignment equipment, you generally can purchase a used "commercial grade" 4 post lift for $3-4000 from a garage equipment company, or try the auctions of dealerships that have closed. Same thing with alignment rigs. For limited use, you don't need a full tilt, 2011, Hunter Hawk-Eye unit. A good, used 4-5 year old Hunter can be gotten again, for $3-4000.
Good luck on the income search!
Many times I take it to a shop and rolled it onto their Hunter. and they Ask WHY I came?
a 1/10 of a degree is meaning less if the tire air pressure is off by 2 psi, or the frame is not square or car is not balanced.
So one does not need to be that actuate for a good alignment.
The Hunter or any other laser for most ppl is perfect.
and my string is a laser.
But I'm sure if I had a shop I'd immediately be rolling some serious dough.I was kind of, of the same impression with hand alignment versus rack alignment. I think they'd be pretty equal because you can only get so accurate. I believe the limiting factor would not be the measuring equipment but the vehicle itself such as tire pressures, chassis alignment etc.
Only thing is a rack is so EASY
I've done manual alignment on a hand built racecar...I was on this team... This was the car for the year after I graduated Not the best video but that thing is SCREAMING fast and corners over 2 G! The one I drove had a huge sprocket (cannot remember how big for the drive-shaft), and 120 HP in around a 400 lb racecar that red lined at 14,000 RPM and had the grip to lay the power down. The CG is only a few inches off the ground too. It was INSANELY fast. I used to work with the team to hand build them from the ground up, chassis, suspension, everything. About the only components we didn't make were the short block, tranny, and wheels lol It was COMPLETELY AWESOME. Ferrari and Jaguar engineers came to ask us questions about their designs and some of the things we had incorporated in our racecars
It was incredible... Anyways, I'm rambling on...It's a PITA to do hand alignment lol Takes FOREVER completely impractical for a shop. It's just no rack would take our dinky little racecar.
A lightweight car with huge low profile tires like the Corvette responds A LOT to changes in alignment. I'm convinced it is alignment changes that are responsible for so many polar-opposite Corvette reviews... one guy says "predictable, confidence inspiring and well balanced" and the next guy will say "scary at the limit, snap oversteer keeps you from fully exploring" etc. Sometimes those comments are from the same person after driving two of the exact same model.
If BG assembles Corvette suspension the same way Oshawa does (an assembly plant I spent a lot of time in), all of the parts come pre assembled set to "spec", are thrown together and never verified. I bet the initial glowing reports of a new Corvette model are a direct result of the car being set up properly before being given to the media. Years later when the same model is featured in a comparisson test the car is just pulled from a press fleet with nothing more than a check of the fluid levels. BS on Gm's part.
I also corner weighted the car, but this was a bit less accurate. I found a two lane road with nice clean pavement and little camber (slope towards the ditch on each side). I straddled the yellow line evenly, revved it up nice and high and dumped the clutch. I adjusted my corner weights until the car was sitting level side to side with a slight rake front to back, and would travel perfectly straight with the rear tires lit up and spinning. This is not an exact science but it made a great difference in off the line traction.
I seriously doubt your string and level system is as accurate as a modern laser alignment,which are accurate to a tenth of a degree. But even those are only as good as the tech who is doing the alignment.
