Engine oil cooler
Old Oct 25, 2011 | 07:53 PM
onevettenut's Avatar
onevettenut
Default Engine oil cooler
I was at the road track last weekend. After 10 laps I had oil temp of 240* and water temp at 208. I was thinking of a oil cooler. What you guys think.
Where did you install it
Old Oct 26, 2011 | 05:41 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
You are not driving hard enough to warrant and EOC, those temperatures are well within the acceptable range for an LS motor. Run a search on oil temperature in the autocross & road racing section, you will find individuals regularly reaching nearly 300 deg F oil temperature.
On a long auto-cross course during the summer time my engine's oil temperature will reach over 250 deg F, I already have a larger aftermarket radiator with an EOC.
Old Oct 26, 2011 | 07:53 PM
onevettenut
Thanks for the input. I will try to go faster next year. The track is going under repair, so track days are done for now
To Engine oil cooler
