A plea for help from the performance gurus...
Old May 5, 2002 | 08:35 PM
VERTVETTE's Avatar
VERTVETTE
Default A plea for help from the performance gurus...
I was thinking of getting the 6.0L truck heads and porting them. If so what can I expect from my boost levels and HP will it be worth doing with out increasing the boost levels I'm curently at :confused:
Old May 5, 2002 | 08:40 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: A plea for help from the performance gurus... (VERTVETTE)
If you lower the compression without raising the boost, you will lose probably 10-15rwhp... But then you will probably pick that power back up, and some extra, if you get some real good porting work done to the 6.0L heads. A cam would also help out.
ARE has a nice Forced Induction 6.0L Heads/Cam package that would be perfect for your application. Drop me an email if you want any information or pricing.
[Modified by MattG, 7:41 PM 5/5/2002]
Old May 5, 2002 | 08:52 PM
VERTVETTE's Avatar
VERTVETTE
Default Re: A plea for help from the performance gurus... (MattG)
TTT
Old May 6, 2002 | 03:07 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
I like MattG's answer, the port work will be worth some ponies, but the lower compression will hurt power a little bit. How about raising the boost, is that possible? That way you can take advantage of the lower compression the heads will give you.
To A plea for help from the performance gurus...
