Carbon build up removal ?
Old Oct 30, 2011 | 08:42 AM
killain's Avatar
killain
Oldtimer
Default Carbon build up removal ?
What is the best way to remove a huge carbon build-up from intake valves and pistons ? What would you use ? and how do I go about doing it ? Thank you !
Old Oct 30, 2011 | 01:15 PM
AU N EGL's Avatar
AU N EGL
Fresh tank of 93 octane and drive it hard. Then repeat for a second tank full
No more carbon build up.
Old Oct 30, 2011 | 02:21 PM
TriplBlk's Avatar
TriplBlk
Really? And what about the top of the pistons? Just curious.
Old Oct 30, 2011 | 02:39 PM
fishmen222's Avatar
fishmen222
Look up the decarb (or SeaFoam) procedure on the search function of both the "tech" and "general" segments of the forum. Very simple to do for less than $10 and thirty minutes of your time. Just make sure to drive the **** out of it afterwards (not that you need an excuse).
Old Oct 30, 2011 | 02:42 PM
cdnguyred88's Avatar
cdnguyred88
But legally
Old Oct 30, 2011 | 02:47 PM
fishmen222's Avatar
fishmen222
Originally Posted by cdnguyred88
But legally
Agreed!
Old Oct 30, 2011 | 03:04 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Put 2 gallons of Xylene in the tank. It will give you about 100-104 or so octane and clean off all your carbon buildup.
Google Xylene and you will see the many uses for it, your car will even run a lot better with that tank of fuel!
Drive it hard at WOT!
Old Oct 30, 2011 | 03:05 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Xylene, 2 gallons in your tank and it will clean all your internals!
Old Oct 30, 2011 | 03:06 PM
AU N EGL's Avatar
AU N EGL
That will work too.
carbon build up is from driving too slow and not enough time at WOT.
Old Oct 30, 2011 | 04:09 PM
David426's Avatar
David426
Seafoam is great.. You can find it at any automotive store
Old Oct 30, 2011 | 04:19 PM
TriplBlk's Avatar
TriplBlk
Better than steel wool on top across the pistons.
Old Oct 30, 2011 | 05:38 PM
fishmen222's Avatar
fishmen222
I am assuming that you are having detonation and/or oil consumption issues. If so, you may want to consider putting a catch-can on your PCV circuit. These LSs are famous oil consumers due to a **** poor PCV design (and ring issues with early C5s). I have built many a baffle in the valve cover(s) of LSs and 5.0 Stangs (forgive me) to alleviate this issue. If you are consuming less than 1/2 a quart between 3-4k, just do the decarb. If more, do the catch can. There are many available on this forum for less than $100, or you can go to Home Depot and get a water/oil seperator for an air compressor for $10. Doesn't work as well...but does the job.
Old Oct 30, 2011 | 06:08 PM
thetaxman's Avatar
thetaxman
water injection cleans them
and you don't need chamicals
Old Oct 30, 2011 | 07:56 PM
zesstey1's Avatar
zesstey1
Will this help with piston slap on cold starts?
Old Oct 30, 2011 | 08:03 PM
fishmen222's Avatar
fishmen222
No...different topic. From what I have experienced, this is relative to the piston skirt vs. cylinder bore diameter. Have had slap on my vette, three f-bodies, and three Silverados. Does not sound good, but as long as you reach operating temperaure before flogging it...all is good.
To Carbon build up removal ?
